I was wondering the same thing, Illum lists the minimum capacity which has a 100mAh difference between the 3A and 10A cells. Not sure why Vapcell carries both since 100mAh probably translates into less than a 5 min difference in runtimes
I know this is slightly off-topic but it still about leds. What is the difference between say,sst20 and orsam.So I guess I want to know more about Orsam leds.I m considering the Acebeam tk16 with orsam leds.
For raw impressive output, I’ve still yet to find anything better than XPL-HI for small triples. XPL-HI offers nearly as many lumens as LH351D, with much more intensity, neutral white color temperature, and excellent rosy tints. Also due to its higher forward voltage it tends to run cooler in these tiny hotrods than other LEDs like SST-20 or Nichia 219c.
If you want to impress your friends, XPL-HI tends to be the most impressive.
Unfortunately, XPL-HI does not come in high-CRI. My current EDC is a modified DQG Tiny 18650 IV running Anduril with three high-CRI Nichia 219C as emitters.
This setup is quite a bit lower output than XPL-HI, but I like the tint, color temperature and CRI.
