Yeah, I implemented LVP for both. It’s configurable, but for now I’ve got it set up so that if the voltage is above 2.0 volts it assumes the battery is lithium ion and uses the typical LVP threshold (2.8v?). But if it’s under 2.0 volts, it assumes a AA and uses 0.7 volts for the cutoff. Again, these parameters are configurable at compile-time.
Yes, we understand that you are very particular (and vocal) about your Anduril preferences. Please realize that this is your opinion and that not everyone shares your opinion.
I don’t know if a final decision had been made about which Anduril version. Heck, Sofirn probably can’t even get the chips to build these. The lights you see me describe and document are built by me, for me, and according to my preferences. And hopefully if Sofirn is finally able to get the proper chips, they include flashing pads. If they include those, you are free to flash whatever firmware you’d like.
All of those things said, I think a slightly customized Anduril2 build would be to Sofirn’s benefit. Having the Simple UI be presented as default would ensure that the same light can work for enthusiasts and “normal users” alike. This keeps them from needing to offer a separate “BLF Edition” and regular version.
There’s a guy on my FW3X thread telling me my argument is daft, he’s saying nobody likes it!
I get why a safe UI option corners the market but that doesn’t mean Toykeeper has to completely butcher the Advanced UI, I mean no option to turn the light off from Turbo? that’s horrific. It’s the only bad thing about the close to perfect Amutorch E3S. Ironically the light might be safer for normal users but it’s also become far far trickier to program. It’s a UI at war with itself.
I guess you’re not following events and just jumping on the TK fan club wagon, TK wants to implement one click from Turbo to return to previously used level.
I guess there’s something wrong with your memory or perception of the reality as this is not what we’ve discussed in the Anduril 2 thread and other places. These are harsh words but still don’t reach your level of perfection.
Amusing discussion. Can’t believe it. Arguing about UI. If you want my opinion, I was mostly interested in the flashlight because I want to try Anduril. Want the most customizable, advanced UI possible. Not sure about an easy dumbed down UI. It doesn’t seem as cool as a frustratingly complex UI one can get lost in. Like the second sub-level of strobe (Rave mode 3) When all you want to do is unlock your vehicle, but a spontaneous dance party starts in the parking lot because you can’t find the right mode. It’s a whole lot more fun in the end because you met 3 new friends & even got a few dates for next week.
I haven’t used Anduril 2 to know whether I’d like it or not. Now I’d be completely happy for Anduril 2 to be tweaked so there’s a Turbo in the Simple UI. Also chuck in the 2C to Turbo as per the standard for so many existing brands and models.
I already had 2C Turbo enabled in my build. But I tend to think you’re right about enabling max output in the Simple UI. To me, Simple UI should be easier to operate, not necessarily be limited in output (like was a consideration for the old Muggle Mode).
