Does order history gets deleted after a few years? Paypal/ebay does the same thing it’s just an inconvenience.
Yes, customers maybe can’t find orders placed a few years ago in their accounts. If you need to check any of your old orders, you can contact us via ticket, our customer service representatives will try the best to provide the order information to you.
SMILING SHARK ES03 EDC LED Keychain Flashlight
3*LED / 6-mode / 3000LM / pure white / 1*20350 / IPX8 waterproof / multi-stage heat dissipation / crush & drop resistant
F401 3*LED 6-Mode 5000LM LED Flashlight
pure white / 4*18650 / IPX5 waterproof / OLED display / stepless dimming / power bank function
6-mode: Long press for 3 seconds to turn on. Strong light-medium light-low light (double click) turbo~~(single click) strobe~~(single click) low light single click to shut down
Any mode stays for more than 8 seconds, it is shutdown
Long press the switch after power on is the stepless dimming function, the light flashes twice when it is adjusted to the brightest, and twice when it is the weakest
Temperature protection and short circuit protection
Automatic power off under low voltage
F402 3*LED 6-Mode 10000LM LED Flashlight
pure white / 8*18650 / IPX5 waterproof / OLED display / stepless dimming / power bank function
SMILING SHARK X28 LED Flashlight
1*LED main light + 1*COB side light / 3-mode / 135LM / pure white / Micro-USB rechargeable / 360’ rotation / IPX6 waterproof / w/ hook
2PCS SMILING SHARK 617A LED Flashlight
1*LED / 3-mode / 240LM / 1*18650 / USB rechargeable / power bank function / IPX6 waterproof
2PCS SMILING SHARK 103A LED Flashlight w/ Focus Zoom
1*LED / 3-mode / 1200LM / pure white / USB rechargeable / IP65 waterproof
SMILING SHARK E512 LED Flashlight w/ Focus Zoom
1*LED / 3-mode / 1500LM / pure white / 1*5500mAh 26650 / USB rechargeable / IPX6 waterproof / power display
Wow! Discount of 15% Site-wide for the 9th anniversary of FastTech has started. Seize the big discount promotion. Shop now→ https://www.fasttech.com/
————————- Anniversary Site-Wide Coupon ———————————
Offer: Site-wide 15% off
Valid Date: Jun 2, 2021 (UTC-6)
Coupon Code: FASTTECH2021
————————- FastTech 9th Anniversary Giveaway ———————————
Offer: Mega Prize for 13 Winners
Valid Date: Jun 7, 2021 (UTC-6)
Quick question?
I already ordered, but had to pull a few small items from what I wanted.
I ordered a bunch of parts that I needed (well, wanted ), and the only shipping option on checkout was 7bux, almost ¼ of the order! So I checked my cart, and almost everything was marked “free shipping”, but 2-3 weren’t. One of those was a small pack of Hall-effect sensors, total weight maybe 2-3 paperclips (oddly, today it shows as free shipping!) and another was a small pack of bare “bead” type LEDs, so it’s not as if the items were bulky or heavy. In fact, they were quite light compared to some other items.
Anyway, even 1 item not marked as “ships free to the US” in the cart triggers the 7buk shipping option.
Like I said, I ordered most of what I wanted, but had to drop those 2-3 small items so it wouldn’t trigger the pricey shipping option. Any way around that in the future?
Solar + USB Powered MTB Bike Bicycle LED Front Light
2*LED / 4-mode / 400LM / pure white / 4000mAh power bank / IPX4 waterproof / w/ 130dB horn (5-sound) / 4-level power indicator light
1*LED+1*COB 7-Mode 800LM LED Flashlight
pure white laser & red light / 1*18650/1*26650 / power bank function / IPX4 waterproof / power indicator light
Head diameter: 68mm
Tail diameter: 35mm
Indicator light: 4 power indicator lights 25–50–75–100
SMILING SHARK E513 Four-color Atmosphere LED Flashlight w/ Focus Zoom
4*LED / 5-mode / 800LM / pure white+RGB / 1*18650 / w/ diffuser filter / built-in 4 wicks / removable light sleeve / water resistant
Head diameter: 30mm, Voltage: 3.7-4.2V
Convoy S2+ 1*Cree XM-L2 T4-7A 499-Lumen 2-Group 3/5-Mode LED Flashlight
1*18650 / AMC7135*4 / lanyard
Reflector diameter: 1.8cm
Head diameter: 2.4cm
Tube diameter: 2.4cm
Tail diameter: 2.4cm
Beam range: 50-100 meters
Lanyard length: 13cm
Voltage: 3-4.2V
To switch mode group: Switch to low mode and wait for 5-10 seconds. As soon as you notice the flashlight automatic blinking, turn off and then turn on, the mode group is then toggled
1*LED 5-Mode 5000LM LED Flashlight w/ Focus Zoom
pure white / 2*18650/2*26650 / USB output / IPX4 waterproof / window breaker
Head diameter: 60mm; Tail diameter: 36mm
1*LED+1*COB 5-Mode 2800LM LED Headlamp
pure white / 3*18650 / hand wave activated / USB output / rear red warning light / power display / IPX5 waterproof
2PCS Solar Powered Up Down LED Garden light Wall Lamp
2*LED / warm white / light sensor / IP65 waterproof
Solar panel: 2V/200mA polycrystalline silicon solar panel
The following environments are not suitable for installation:
Glass room (Although there is sunlight, the glass is blocked, which affects the intensity of light. It affects battery charging)
Monitoring area (the monitoring area is not suitable for installation, the monitoring has infrared rays. It will affect the brightness of the light)
Under the tile eaves (the area where the lamps are installed must not have tile eaves, trees, wires, etc.)
Short exposure time (the area where the solar lamp is installed must be exposed to sunlight for at least 6 hours)
SingFire SF-348 LED Flashlight
authentic / Cree XP-E R3 / 1-mode / 180LM / 1*10440/AAA / clip
Reflector diameter: 9mm
Head diameter: 12mm
Tube diameter: 12mm
Tail diameter: 12mm
Beam range: 30 meters
Working voltage: 1.5-4.2V
