6-mode: Long press for 3 seconds to turn on. Strong light-medium light-low light (double click) turbo~~(single click) strobe~~(single click) low light single click to shut down
Any mode stays for more than 8 seconds, it is shutdown
Long press the switch after power on is the stepless dimming function, the light flashes twice when it is adjusted to the brightest, and twice when it is the weakest
Temperature protection and short circuit protection
Automatic power off under low voltage
I already ordered, but had to pull a few small items from what I wanted.
I ordered a bunch of parts that I needed (well, wanted ), and the only shipping option on checkout was 7bux, almost ¼ of the order! So I checked my cart, and almost everything was marked “free shipping”, but 2-3 weren’t. One of those was a small pack of Hall-effect sensors, total weight maybe 2-3 paperclips (oddly, today it shows as free shipping!) and another was a small pack of bare “bead” type LEDs, so it’s not as if the items were bulky or heavy. In fact, they were quite light compared to some other items.
Anyway, even 1 item not marked as “ships free to the US” in the cart triggers the 7buk shipping option.
Like I said, I ordered most of what I wanted, but had to drop those 2-3 small items so it wouldn’t trigger the pricey shipping option. Any way around that in the future?
Reflector diameter: 1.8cm
Head diameter: 2.4cm
Tube diameter: 2.4cm
Tail diameter: 2.4cm
Beam range: 50-100 meters
Lanyard length: 13cm
Voltage: 3-4.2V
To switch mode group: Switch to low mode and wait for 5-10 seconds. As soon as you notice the flashlight automatic blinking, turn off and then turn on, the mode group is then toggled
1*LED+1*COB 5-Mode 2800LM LED Headlamp
pure white / 3*18650 / hand wave activated / USB output / rear red warning light / power display / IPX5 waterproof
Solar panel: 2V/200mA polycrystalline silicon solar panel
The following environments are not suitable for installation:
Glass room (Although there is sunlight, the glass is blocked, which affects the intensity of light. It affects battery charging)
Monitoring area (the monitoring area is not suitable for installation, the monitoring has infrared rays. It will affect the brightness of the light)
Under the tile eaves (the area where the lamps are installed must not have tile eaves, trees, wires, etc.)
Short exposure time (the area where the solar lamp is installed must be exposed to sunlight for at least 6 hours)
4PCS SMILING SHARK 612 EDC LED Flashlight
1*LED / 4-mode / 400LM / pure white / 1*14500 / clip / IPX6 waterproof / anti fall
Voltage: 3.7-4.2V
Head diameter: 22mm
Tail diameter: 22mm
