I don’t believe that’s correct. The SST-70 is a 5 sq mm package. The emitting area is only slightly larger than the SST-40.
It should be correct as the SST70 consists of four SST20 led dies which are 2 square mm each, for a total of 8 square mm. You need to consider that the footprint is 5x5 mm, so 25mm². 7mm² is 2.65mm at each side so it fits well.
But you are right, 2.65mm die lenght for the SST70 and 2mm for the SST40 is quite a small difference.
A 5mm square is 25mm². SST-40 certainly is 4mm² (2mm*2mm). Square root of 7 is ~2.65. So yes, the side length it’s only slightly larger, but area nearly double.
Ah, I see. Thanks
Aux LEDs serve me 2 purposes:
- they indicate voltage (by changing colour)
- they tell me whether the light is locked out (If they are dim, the light is locked out)
Both things are of huge importance to me.
But at the same time:
- These are the fanciest indicators but neither the cheapest nor the simplest ones. A switch RGB LED would work exactly as well.
- My fork of Andruil puts heavy emphasis on lockout. Maybe a simpler Convoy UI doesn’t need it at all
So…I somewhat agree with what was said before, AUX lights don’t really fit the Convoy’s quality at budget price niche. At the same time I find voltage indication to be of huge value and I suggest Simon that you evaluate options to make it accessible to customers.
Simon:
- I can't find any trace of a 3x21A flashlight, yet posts date back to September on it being in production. Am I missing or mis-understanding something?
- You listed a 3x21A available with a P2 bin SST-40, are those available or will be available for purchase separately, and are they 6500K or 5000K?
Thanks!
Voltage indicator is always useful.
More than Aux Leds and considering that Emisar don’t want made a quad light with adjustable temperature, I wish for quality LEDs bin below BBL that provide a wide range temperature like Nichia E21A start from 2000k to 5000k
And a regulated Driver with smooth ramp with each channel adjustable from sublumen and No PWM
Flat-to-Top head plastic adapter for battery is being produced, and it will take about two days.
interested in “P2 bin SST40” To purchase bare? Would we leave a “note to seller” for P2 bin, when buying sst40 on your store?
Same here - meant to ask if the P2 SST-40's can be bought bare, and what tint they are, thanks!
it’s P2 bin in stock currently ,There is no need to specify it in the remarks.
BA bin,
But the batch update is fast,
I'm confused - the Ali store still specifies "N5" as the flux for both 6500K and 5000K. Is the 5000K also available now in the P2 flux?
Simon, have you ever made the S2+ in brass (yellow copper)? I don't remember ever seeing or hearing about one but I would love to own it someday! I do remember the smooth red copper one a few years ago but did not buy.
I know brass is slower to machine than aluminum and more expensive but I think it would be a very nice option. The couple of brass lookalikes from other companies I have seen have been poor quality.
Yes he did 2 batches , or was that copper? (The 2 batches which were not compatible with eachother due to different threads)
Maybe there can be a 3rd batch?
Simon,
can your do the L21a with xhp35 in the silver body? Do I just request in checkout? Thank you.
Hello Simon, when will the L7 be available in the shop?
Quick question - I assume that the M21C GT-FC40 can run with a Samsung 50E 21700?
The LED BIN in the aliexpress store has not updated information, most of which are higher than the marked FLUX level
I don’t like brass very much, it is very heavy, and the thermal conductivity is not as high as aluminum alloy.
At present, the price of various metal materials is rising very sharply. At least for this period of time, I will not consider producing brass or copper flashlights.
