According to the review, the Sofirn-branded cell is a button top battery. Does anyone know, if flat top 18650s will work as well in the SC31 Pro without any problems?
Thanks a lot in advance!
I was looking at them too. Thanks for the help. Do you know whether the USB charging of the SC31 pro is too high a current for 18350 cells? I saw 1.87 amp while charging a 18650. I was wondering if the top current self adjusts to a lower current when an 18350 battery is being charged?
I just remembered I have a fully charged 16340 to test in the shorty tube. It did charge at a lower rate of .90 amp. Max charge current is about .5 amp for a 16340 so not good . It did drop steadily though.
Good tip. The second time I read that from you and I completely forgot. What rate do you see charging an 18350 from a 2 amp charger or haven’t you looked? It would be nice to be able to charge from the car or out and about if I could. I’m on the fence about buying 18350s. Another thing, my shorty tube that came with my SP 40 headlamp screws into the head either end but the tail cap only screws on half way on one end though it will screw on either end of the 18650 tube. Weird .
The SP10 Pro is special because its output is relatively low. Thus the ceiling in both modes is set to 150 by default. Other lights should be different. Also simple UI should always be lower than or equal to advanced UI.
Interesting. I can’t remember having ceiling setting changed, and in advanced mode, double clicking on max ramp does nothing. Should be 150/150 then? Could very well be senile dementia on my side, of course.
to get to 150/150 in advanced we must first manually Ramp to ceiling (if we double clic to ceiling, there is no double clic to Turbo). After Ramping to ceiling a double clic goes to Turbo.
