4PCS SMILING SHARK 612 EDC LED Flashlight
1*LED / 4-mode / 400LM / pure white / 1*14500 / clip / IPX6 waterproof / anti fall
Voltage: 3.7-4.2V
Head diameter: 22mm
Tail diameter: 22mm
Get ready to grab the best products from variety of ranges at affordable price from FastTech! It is time to celebrate the Independence that we enjoy from the hands of our freedom fighters.
————————- Independence Day Site-Wide Coupon ———————————
Offer: Site-wide 10% off
Valid Date: July 3, 2021 - July 4, 2021 (UTC-6)
Coupon Code: IND2021
Voltage: 3.7-4.2V
Head diameter: 55mm
Tube diameter: 28mm
With low voltage protection and temperature control protection
Mode operating instructions:
Click button —> flashlight is on with last brightness —> press button, brightness ramping up -> release and press button again, brightness ramping down
Flashlight off, press button —> moonlight mode 0.01a (0.2%) [this glow will not be remembered]
Flashlight on or off, 2-click the button-> 100% turbo
Flashlight off, 3-click button->strobe
Flashlight off, 4-click button —> tactical mode, only 100% ,4-click button again to exit tactical mode.
Flashlight off, 5-click button —> voltage detection (* means “flash”, * pause* means 3.7V, )
Flashlight off, 6-click button —> normal ramping mode switch for 4 modes 1–10–40–100
Flashlight off, 10-click button —> lock mode, flashlight will flash once under any operation, which means flashlight is locked. 10-click button again to exit lock mode, please note that this is the only way to unlock.
Voltage: 3.7-4.2V
Head diameter: 55mm
12 groups of debugging text description:
Click the switch to turn on/off the flashlight, half-press the switch to select the mode
If the flashlight is turned on, quickly half-press the switch 20 times to enter the configuration mode. (On a visual interface (such as a mobile phone), as long as you click on an option, it means that the option is selected. The flashlight has no visual interface, it uses flashing to indicate an option, and “half-press the switch during flashing” means Select this option.)
Option 1 (normal flashing once + buzzing flashing): half-press the switch to enter the sub-options, start to select the gear group, if the user does not operate, the configuration mode enters option 2.
Option 2 (normal flashing twice + buzzing flashing): half-press the switch to activate or deactivate the gear memory. If the user does not perform any operation, the flashlight will enter the last gear.
Power detection instructions: <2.95V 1 flash, 2.95-3.25V 2 flashes, 3.25-3.55V 3 flashes, 3.55-3.85V 4 flashes, >3.85V 5 flashes
