1*LED+16*COB 4-Mode 700LM LED Flashlight
pure white / USB rechargeable / IPX3 waterproof
Head diameter: 60mm; Tail diameter: 35mm
Authentic XTAR T2 Mini EDC LED Flashlight
1*Cree XP-G3 S4 LED / 7-mode / 650LM / pure white / 1*10380 / lanyard
Head diameter: 38mm
Dear valued customers,
Get ready to grab the best products from variety of ranges at affordable price from FastTech! It is time to celebrate the Independence that we enjoy from the hands of our freedom fighters.
————————- Independence Day Site-Wide Coupon ———————————
Offer: Site-wide 10% off
Valid Date: July 3, 2021 - July 4, 2021 (UTC-6)
Coupon Code: IND2021
SMILING SHARK ES03 EDC LED Keychain Flashlight
3*Luminous SST20 LED / 6-mode / 3000LM / pure white / 1*18350 / IPX8 waterproof / multi-stage heat dissipation / crush & drop resistant
Convoy S2+ LED Flashlight
1*Luminus SST40 LED / 4-mode / 1800LM / pure white / IPX8 waterproof / 1*18650 / w/ lanyard
Drive: 7135*8
Voltage: 3-4.2V
Head/Body/Tail diameter: 24.1mm
New Arrival Convoy M21D LED Flashlight
1*LED / 12-group / 4300LM / warm white / 1*21700
Voltage: 3.7-4.2V
Head diameter: 55mm
Tube diameter: 28mm
With low voltage protection and temperature control protection
Mode operating instructions:
Click button —> flashlight is on with last brightness —> press button, brightness ramping up -> release and press button again, brightness ramping down
Flashlight off, press button —> moonlight mode 0.01a (0.2%) [this glow will not be remembered]
Flashlight on or off, 2-click the button-> 100% turbo
Flashlight off, 3-click button->strobe
Flashlight off, 4-click button —> tactical mode, only 100% ,4-click button again to exit tactical mode.
Flashlight off, 5-click button —> voltage detection (* means “flash”, * pause* means 3.7V, )
Flashlight off, 6-click button —> normal ramping mode switch for 4 modes 1–10–40–100
Flashlight off, 10-click button —> lock mode, flashlight will flash once under any operation, which means flashlight is locked. 10-click button again to exit lock mode, please note that this is the only way to unlock.
Just ordered the 3X21A SFT40 using your coupon, thanks for a good deal!
AlexGT
Dang, should have waited. Ordered mine from Convoy for like $72 after taxes, etc. Using the BLF coupon code, free shipping, it's $9 cheaper here.
It was actually less than $60…
I couldn’t resist at $54 either. Added the HK4s, too. I am betting I use that more than the convoy 3x21.
EagleVision Car LED Fog Light Bulb
30*2525 LED / 3000LM / white & yellow light / IP65 waterproof / heat dissipation
How was it this cheap?
There was a coupon code for independence day, total was 97.39 for both those lights. I paid more for 3x21700 and 3x26650 cells from illumn!
Ahh, post #1108.
New Arrival Convoy M21C LED Flashlight
1*LED / 12-group / 2000LM / pure white / 1*21700
Voltage: 3.7-4.2V
Head diameter: 55mm
12 groups of debugging text description:
Click the switch to turn on/off the flashlight, half-press the switch to select the mode
If the flashlight is turned on, quickly half-press the switch 20 times to enter the configuration mode. (On a visual interface (such as a mobile phone), as long as you click on an option, it means that the option is selected. The flashlight has no visual interface, it uses flashing to indicate an option, and “half-press the switch during flashing” means Select this option.)
Option 1 (normal flashing once + buzzing flashing): half-press the switch to enter the sub-options, start to select the gear group, if the user does not operate, the configuration mode enters option 2.
Option 2 (normal flashing twice + buzzing flashing): half-press the switch to activate or deactivate the gear memory. If the user does not perform any operation, the flashlight will enter the last gear.
Power detection instructions: <2.95V 1 flash, 2.95-3.25V 2 flashes, 3.25-3.55V 3 flashes, 3.55-3.85V 4 flashes, >3.85V 5 flashes
3PCS SMILING SHARK 867A LED Flashlight
1*LED+1*COB / 4-mode / 240LM / pure white / 1200mAh power bank / IPX6 waterproof
Head diameter: 21mm
3*LED 6-Mode 3900LM LED Flashlight
pure white / 1*26650 / IPX5 waterproof / power bank function / multi-stage heat dissipation
Head diameter: 55mm
Tube diameter: 50mm
Overcharge and overdischarge protection
1.5m drop protection
Convoy L6 LED Flashlight
1*LED / 5-mode / 3500LM / neutral white / 2*26650 / IPX6 waterproof
Head diameter: 75mm, Max intensity: 135KCD
