I would be interested to compare the beam angle between this and the Q8 Pro.
Interested in SFT40 version
interested in sft40 version
Interested.
SFT40 order placed. Thank you
Interested in SFT40 version.
Thanks
Interested in sft model.
Order placed for a 3X21A SFT40 version, thank you for the coupon.
What is a good 21700 5000mah battery for it?
Molicel NPE INR-21700-M50A 15A 5000MAH FLAT TOP
or
VAPCELL G50 21700 15A FLAT TOP 5000MAH
Any other high capacity and high discharge cells you would recommend?
Thanks!
AlexGT
I would think this would be good as well (US customers)
Thanks for the suggestion, will look into it.
I am wondering does this light accept button top cells or does it have to be flat top with the provided adaptor?
interested.
thank freeme for my request.
interested
Thanks
Is this the same host as 4x18650 sbt90
2? Looks the same.
Interested
interested SFT40
Is this the same physical size as the 4x18 SBT90.2?
4X18A (3X21A)
Head diameter 69mm (69mm)
Battery tube diameter 50mm (51.8mm)
Flashlight length 153mm (158.4mm)
Product weight 458g (569g)
Is the SFT40 available, seems sold out.
