✅【 GROUP BUY 】Convoy 3X21A 3*SFT40/SST40 6800LM 3*21700 Flashlight ✺
✺ CONVOY 3X21A ✺
3xSST40/SFT40 Flashlight
Group buy price - $58.49-63.11
Specifications:
Brand
CONVOY
Product name
Flashlight
Material
Aluminum alloy
Low voltage warning
Automatic power off
Reverse polarity protection
None,The positive side of the battery should be facing the head
Lens Type
Ar-coated glass lens
Reflector
Smooth
Charging
TYPE-C charging interface (charging current 3A)
Switch position
Side button in the head
Mode memory
Yes
Tail stand
Yes
Battery included or not
Not included
Battery type required
3*21700 batteries (unprotected)
Luminous flux
Maximum 6800LM(SST40)/5400LM(SFT40)
Illumination
Maximum 265KCD(SFT40)/142.5KCD(SST40)
Range
Maximum 1029m(SFT40)/755m(SST40)
Tc
6500K/5000K
Output current
17.8A (SFT40)/16A(SST40)
Head diameter
69mm
Battery tube diameter
51.8mm
Flashlight length
158.4mm
Product weight
569g
Weight with box
706g
Packing size
183 * 98.5 * 78.9mm
If you are interested notify in this thread (not in PM)
My thread:
BangGood.com Deals
reserved
Interested in SFT40 version, if it is the 3x21A like in your picture.
I am considering buying either this Convoy 3 x 21A or Sofirn Q8 Pro.
The 7.7 Sale in Singapore is approaching. The price of Q8 Pro will come down to just around US$60 (without battery).
On paper, the Q8 Pro claims to generate up to 11,000 lumens, whereas Convoy 3 x 21A can produce only about 6,000.
Can anyone share insights in comparing these two lights? What are their major pros and cons?
Convoy 3x21a will have much more throw. Much more. So you will need to decide do you want twice as many lumens (bright) or twice as much throw (distance), may not be twice as much throw but it will be noticeable to the eye.
Interested!
this will probably be the one new Convoy I buy right away. I have enough sbt90 lights, and this will save me from having to modify the ft02s with sft40. Can't wait for this light.
I just wish the head was bigger like 80mm :)
Interested, Anyone have a size comparison photo next to a BLF Q8?
What UI does it use?
Thanks Artiet59 for your insight.
Now I am leaning towards buying this Convoy light. I have a Sofirn Q8, and so in no urgent need for the Q8 Pro.
BTW, can we expect more “discount” offers during the upcoming 4th of July holiday?
I am outside of the USA; therefore, I don’t know the shopping business strategy or whether such sale event is going to happen at all during such a major American holiday.
Here in Singapore, sale is happening every month. Last month it was the 6.6 Sale. Now the 7.7 Sale is coming. And next month, it will be an even bigger monthly sale of 8.8 which will coincide with Singapore’s National Day on 9 August.
I would be interested to compare the beam angle between this and the Q8 Pro.
interested in sft40 version :stuck_out_tongue:
Interested.
SFT40 order placed. Thank you :slight_smile:
Interested in SFT40 version.
Thanks
Interested in sft model.
Order placed for a 3X21A SFT40 version, thank you for the coupon.
What is a good 21700 5000mah battery for it?
Molicel NPE INR-21700-M50A 15A 5000MAH FLAT TOP
or
VAPCELL G50 21700 15A FLAT TOP 5000MAH
Any other high capacity and high discharge cells you would recommend?
Thanks!
AlexGT
I would think this would be good as well (US customers)
Thanks for the suggestion, will look into it. :slight_smile:
I am wondering does this light accept button top cells or does it have to be flat top with the provided adaptor?
interested.
thank freeme for my request.
