Neal showed me his prototype but he went offline soon after.
Damn that looks very EDC pocket worthy, INTERESTED !
Interested
Specifications (Preliminary):
- Emitter: LEP
- Optic: harden glass optical lens
- Flux: 385lm
- Throw distance: 1170m
- Intensity: 3,420,000Cd (30m)
- User interfaces:
- High (380lm)> Med (150lm)> Low (30lm) with memory
- RGB AUX at tailcap when OFF
- Runtime: 5m \_ 40m / 58m / 2h20m / 60d standby (computed based on 900mAh 18350)
- Battery: 18350
- Driver: Designed by Lumintop.
- Parasitic drain with RGB ON is about 0.5mA
- LVP: 2.8V, warning at 3.2V (triple flash)
- Stepdown when temperature exceed 55°C
- Body: aluminum with hard-coat anodizing
- Switch: clicky tail switch
- Ingress rating: Equivalent to IPX8
- Weight: approximately 102 g without cells
- Size: 32 mm Ø head x 25.5mm body X 96 mm length
3.4Mcd in a package this small?!!! Definitely in! Haha.
1170m equals 342kcd, so guessing someone just got excited with the zeros. That’s still damn impressive in a light that small though, so hope the numbers are accurate
Sounds interesting, would love to hear more about the price.
Will update me list in an hour. If you wish to jump in, make it quick!
Any chance of a pocket clip?
100% interested!
i unfortunately slept on the aluminum Thor Ii, and the Ti is out of my budget.
But all that aside! This size! True winner to me!
and I actually really like the styling!
Nice work Lumintop!
im intersted!
Hope I didn't miss it? I just saw this now!
No credit taken away from Simon at Convoy, but this HAS TO BE the most INTERESTING light so far in 2021. Very excited!
Interested
Interested
L21’s with the SFT40 and an L7 with the SBT-90.2 are certainly there for me! LEP’s are pretty specialized so, for me are really a specialty item separate from mainstream flashlights.
I saw Vinh's measurements too and wondered why they were SO below spec? worried me actually, especially since freeme claimed to get 1700+ meters. Then again, VInh has really questionable measurements for the FireFlies e12r with sst20 4000k, something like 3800 lumens, which doesn't make any sense (even @ 450 lumens/emitter which is a low average, that is 5400L). so maybe another biffle on his part? or he doesn't understand how to operate Aunduril 2 (in all seriousness, its quite different and comes in on "muggle" mode).
You edited and said that Thor II did hit spec, where did you confirm this if you dont mind i ask?
I agree! And hoesntly simon has been crushing it with amazing new offers. but so is Freeme in a different way
Marco 1lumen just published 891,000 cd 1888m in his review. David and I got close to 1800m, so I shouldn't think there is much to dispute on Lumintop ratings.
Th558:For the THOR II, Vinh got 195Lumen, 550Kcd, 1483m which is way below spec. Has anyone else tested it? Hopefully this one doesn’t underperform as well. Edit: It does actually hit the claimed 1.8km so this might hit the claimed 1.2km too.
Interested in SS.
ArtieT59: Th558:For the THOR II, Vinh got 195Lumen, 550Kcd, 1483m which is way below spec. Has anyone else tested it? Hopefully this one doesn’t underperform as well. Edit: It does actually hit the claimed 1.8km so this might hit the claimed 1.2km too.
great to know! I have no issues with that, I was just curious.
Seems like a typo. By the throw distance, it is probably 340kcd, one less zero.
