WildTrail WT90 - SBT90.2 1800m+ throw 90mm 3x 21700 With Texas_Ace driver
This has to win flashlight of the year.
I love photos like this!
I remember I bought 2 Lumintop SD75 that featured inboard re-chargeability AND power bank functions, though it had a much simpler design as the carrier was the usual 3-cell carrier with the charging circuit situated at the bottom of the battery tube.
Both SD75s had horrendous parasitic drain that it ruined two sets of 18650s. Perhaps more design research is needed to mitigate this problem, at least for me.
Personally, I will have to wait for the WT90 to iron-out this parasitic problem before I dive for this light as I am really a fan for this light’s design, performance and powerbank versatility, but a phobia for lights that has parasitic drain issues.
i was saving $$ to buy the new Lumintop top SD90 like 2 weeks before TA dropped this group buy! I wished the head was larger on that light because it looks pretty awesome otherwise. While I was trying to dig for info on it because it was new, I found 5+ year old YouTube reviews of the SD75, which seemed like it's predecessor but with the xhp70.2 . I haven't seen much about the sd90 since the WT90 came out. Interesting lol (it is $40-$50 more than the WT90 with a 10mm smaller head, which I equate to less throw).
it gets my vote, with the Emisar DT8 at a close second. But regarding value/thermal design/aesthetic (IMO)/ and performance: the WT90 is unparalleled.
Both tests were started AFTER 12 Hours of Rest after being Fully charged.
After 4 days the original carrier dropped from 4.23V to 4.17V. A 0.06V loss.
Below is Toms modded carrier that he swapped with mine.
Started at 4.21V and after 4 days was 4.20V.ONLY lost 0.01v.A typical loss not associated with parasitic drain.
Conclusion…SUCCESS :+1:
Off to the dentist.
Ok, good to know!
Disabling the charging on the carrier should remove all parasitic drain from the carrier leaving only yhe normal parasitic drain from the driver itself which generally takes 2 years+ to drain a set of batteries.
Sadly I do not see the charging parasitic drain being fixed while keeping the charging working. This is why I don’t care for internal charging. It can be done but takes a lot of extra work to make it work properly.
Updated the OP
Thank you. My Google Drive links were unfortunately messed up by some update, so I had to restore some information, e.g. manuals. If you want to update the link to the manual once again, here’s the new link:
updated
What is it about internal charging that causes parasitic drain?
The Charge circuit IC’s are simply not designed to have the low parasitic drain that we need. They are designed for items that are used regularly or need constant monitoring.
It can be made better but takes more expensive components and R&D that most flashlight manufactures are not even aware are necessary. Parasitic drain is something that manufactures seem to completely ignore for some reason. I have a few lights that from the factory would drain the cells in a few months.
Last night.
A lot of moisture in the air and even more haze from the Canadian and West Coast USA fires.
Across the River about 125 yds. To target, A Sycamore Tree.
That thing is a pure beast. Love to see a pure copper version.
that would be amazing
Ok, just got word, this weekend will be the end of the group buy.
So anyone that wants a WT90 at the GB prices grab them while you can!
Quite surprised to see the slow sale of the WT90. The Black version hardly moves on Ali Express’s web page for days, still 51 pieces available.
I have grabbed one Silver. Will wait to get one Black if the price drops later this year.
BTW, what happens to those large and expensive flashlights (each costing over US$200) which have been left unsold over the years? Just saw on Olight’s website, soon the new X9R will be on sale for about US$500. What will happen to the older Marauder 2, which is priced over US$200?
X9R has been around for a while. Marauder 2 came after it. The only thing that’s new is that it’s blue now. I imagine they will continue to carry both models. The X9R will go back up to $600 when the sale ends.
The same thing that happens to anything that does does not sell. Flashlights are no different.
