With the damping grease, that was my experience also. The more you add the more resistance it offered in ring rotation.
I think me and you like about the same feel in the ring. I want it to turn smooth with some resistance but not too much.
If others are repacking their grease on these rotary lights, just experiment a little to get the feel you like.
If it turns to freely add more grease, if it is to hard to turn take a little out. Find what you like and go with it.
Since Sunwayman is gone,someone know if there is compatibility with the Driver of RRT01 on the room head of V11R? In addition to the dimensions, it’s necessary to verify that the magnetic control will work correctly
The Sunwayman driver is a single pcb driver, the RRT is a double stack PCB driver. The top PCB on the RRT driver will not fit down inside the Sunwayman driver cavity, its to tall to fit. There’s not enough material there to remove to make it fit.
I have never found a driver replacement for the Sunwayman’s. The only option would be to purchase another V11R since they were the cheapest of the rotary lights. Most of the components on the driver can be purchased and replaced if bad. From what I understand about the datasheet of the 316BCG rotary position sensor it has to be programmed, so it may not be able to just be replaced. In my experiences the PAM2803 is what usually dies on these drivers. More info How to Mod Sunwayman V11R or V10R Driver For More Current
^ Looks great, Jon. I really love this host. Kind of regret never bothering to get one. TCR-1 was on discount for a brief period before vanishing from retail stock, but at that time I still considered it too pricey.
Happy to hear again you Moderator and thanks for tried.
My V11R driver work but there is an issues at about 3/4 of rotation it start to flicker,during progression the problem disappears but brightness doesn’t increase anymore.That happen with AA doesn’t have lithium atm. I’ll read your guide,checking driver,contacts and the magnetic ring
Hi guys which newer RRT01 driver should I order from Jetbeam for the replacement? It is good to buy some spares in case they discontinued the production of RRT01. I got the 2011 version. Thanks!
I prefer the 2011 and 2012 original drivers. they are less likely to flicker visibly at sublumen outputs. The 2012 version added strobe.
2011 and 2012 drivers cannot be purchased anymore.
you can buy as a backup, either
2019 driver, it has higher output, but can flicker visibly at sublumen levels
or
2020 driver, it has same higher output, plus thermal step down, it can also flicker visibly at sublumen levels
it is not documented anywhere, just my own observation of a few of my lights, and confirmed by a friend who owns about 5 RRT-01, that he upgraded to 2020 drivers…
you be the judge, if you cant see it, I would not worry
Luck of the draw. My 2012 RRT01 flickers on sub-lumen output, both my EYE10 and 2019 RRT01 don’t. All three have been serviced, i.e. taken apart completely, got new LEDs and silicon grease.
The flicker/pulsing is really strange. I estimate its frequency at about 20 Hz, but what generates 20 Hz? Or is it beating, i.e. two clocks being slightly different?
Modded a 2012 RRT01 today. Cree XPP 3000k 90cri, with a Kaidoman “18mm x 12mm” 5mm opening reflector. Only reason that is in quotations is because Ive ordered multiple 18x12-ish sized reflectors over the last couple of months and this one isn’t exactly the size of any of the reflectors listed on Kaidoman. I’ve included pics of the reflector measurements. I had to triple stack Convoy 16mm mcpcb’s (3535 size) to compensate for the height difference between the stock reflector and this new one. It worked out well as it brought the lip of the reflector right to the edge of the head so the bezel now closes all the way with the stock lens installed. I did not use a centering ring as the XPP in this small reflector focuses really well without one. I just installed kapton tape to cover the leads (and ended up covering the entire mcpcb with Kapton Tape).
Overall Im really happy with the mod. I always take the opportunity to use an XPP when I’m not worried about overdriving it. I had an SFT40 3000k in this yesterday with the stock reflector but there was a pronounced ring around the hotspot i couldn’t get rid of. Im pretty sure its bc of the design of the stock reflector. This setup will likely remain as its a pleasing beam and tint, and hi cri.
