The thermal resistance of the 50.3 is much improved over the 50.2, .4°C/W vs 1.2°C/W.
Nice ! 4500K, 90 CRI, 6V/12V
We should take bets on what the duv of this bin will be
And they’re going to stock it in December. I already know what I’d put it in.
It’s domeless, so at least it will be consistent
oh, quite interesting, flat XHP50.3
Thanks for sharing this information, thefreeman and the rest of you. I made my own, specific search for CRI90+ HI emitters at Mouser EU.
Wellp, out of 39 entries only the H2-45G (3-step 4500K) is available in small quantities. Other interesting easywhite parts are listed, like this F4-27H (F4 bin, 2-step 2700K), or this G2-27H (G2 bin, 2-step 2700K), these are “incandescent” while as close to the black body locus as Cree “bins” them. The second page of the above search contains many 2-step emitters.
I'd love to get a few “warm” HI emitters, 3500K or 4000K tops…
Sat, 10/16/2021 - 16:16
Not super hopeful, but without the whole package phosphor pour it’ll probably be more uniform, both for HD and HI, slicing might be a good option for obtaining lower duv ”HI” (with slightly lower perf since apparently they use some sort of texture to improve light extraction on flat lenses), and without the need to dice them it’ll be easier.
to reconfirm
50.3 HI DOES NOT COME IN 3V
only HD will be 3V
Cheers
Hey mate i ordered a few XHP50.3 HIs and the new MCPCB design has the two solder dots that sit beside the LED and they interfere with the LED gaskets sitting flush with the MCPCB, do need them?
Like excess solder beads? You can remove them with a razor blade
I think these have to be filled but not sure how much is needed because its in the way of the centering ring. See the two beads one on each side of the LED its below the J? Its meant to be there but it would be better of in a different place.
Even if you put solder in the R position its a bad spot for the centering ring.
Ahhh. Yes. Poor placement indeed. I’d take a mini flat file or even an emery board and sand the solder blobs down a bit. Also, while it may be a pita, grooves could be filed into the centering ring. At least they are 180° apart, so the second idea is probably best
grooves could be filed in the centering ring
Or drill holes, probably easier.
I would use a scalpel with curved edge to cut away the solder.
Certainly bad board design, at least for flashlight users. It can be converted to 4S or “12V” voltage, but the connection points on the MCPCB are also rather close to the emitter and this could also cause problems with wide base reflectors.
Reflowing the emitter is also a choice, but of course only if you are able and have spare boards. Being thrifty, long ago I chose these…
Desoldering pump should do the trick.
Micro shears Just snip the tops off
Has anyone tested the 50.3 emitters in a direct drive setup yet? If so what kind of current did you get?
According to the XHP50.3 datasheet the voltage is the same as XHP50.2 except that the thermal performance of the 50.3 is significantly better so the Vf should be just slightly higher due to that.
Speaking of the thermal performance: the XHP70.3 datasheet says .2° C/W thermal resistance! And the P4 bin will be available. This sucker might hit 10,000 lumens.
That will be exciting. My L6 might need an upgrade.
