The first batch of all MK38 (white) Micro-arc oxidation have been pre-ordered. We urget to add 2nd batch to produce.the estimated finish will be at end of this month or early next month.
so If you make the order of MK38 (white) Micro-arc oxidation after 11.11, we can start to ship them to you at early next month (December). but we will ship them to you via fast express if possible.
lumens and runtimes in each levels? please patiently wait for some more time. Once we fiish all sample test, we will list all tech data at official website as soon as we can.
If you are from european union, please contact local dealers to buy MK38 in the future.
Exactly the same performance as the Acebeam X50, both lights too expensive and with a modest runtime, I'd like to see a comparison with the Imalent MS08 which promises 10000 continuous lumens thanks to its cooling fans integrated into the case.
I'll answer you, it's very simple because those you see on their site are prices in US dollars without VAT because in the US there is no VAT, if they sent to Europe they would have to increase the price to the extent of the VAT of the various countries, in Italy for example in the my country of 22% and here is that the discount of 25% should be absorbed by the VAT, resulting in an exorbitant price in relation to the product offered.
Don’t forget the White one is Micro-arc Oxidation which is applied differently to Type-III hard-anodized Oxidation - Micro-arc Oxidation is supposed to be harder than stainless steel and titanium so not just for looks - also if scratched it will be more forgiving showing the silver alu underneath compared to black with silver nicks.
Can you explain the difference between Built-in Battery Pack vs 3x 21700 Battery? Is the battery pack made of 3x21700? 12000mah? Do both options support battery bank? It looks like they are both the same price?
If you select the power option:'Built-in Battery Pack & Fast Charging & Powerbank', your MK38 are built-in 10.8v 4200mAh battery pack, and have super fast charging and discharging functions and can support protocols of QC3.0 & PD3.0,Huawei & Oppo...
If you select the power option:'Power by 3x 21700 Battery (Battery NOT Included)' your MK38 need to be powered by 3x 21700 batteries. This item has not included any battery.You need to purchase 3x 21700 batteries from other sellers. of course your MK38 will have not super fast charging and discharging functions.You need to buy charger to charge your battery, and you can also not make your MK38 as powerbank to charge other device. To get best user experience, we highly recommend you to buy flat-top unprotected Samsung 40T 21700 battery or flat-top unprotected Molicel P42A 21700 battery.
Whatever you select the power option:'Built-in Battery Pack & Fast Charging & Powerbank' or 'Power by 3x 21700 Battery (Battery NOT Included)', your MK38 have the same constant current circuit and the similar output etc.
