Yay
congratulations!
well done
I hope it arrives soon and solves the high drain problem
please let us know
Yay
congratulations!
well done
please let us know
"We are in China, so we don't need to send back bad heads. Shipment will be arranged one week later, and you will be given a tracking number after shipment."
So I just had to email info@jetbeamlight.com, not the info@niteye.com that is for EU region. Even though I'm in EU
Will update when it arrived, and will do drain measurements again.
posting to consolidate parasitic drain (standby drain), and moonlight drain info:
How long will the RRT-01 last with an 1200mah battery, if the light is used as a nightlight, 24/7 on a very very low output level?
I think the answer is less than a week
for reference, the standby drain is confirmed to be about 30 micro amps,
and would last about 4 years w a 1200mah battery…
I hope I got those numbers right…
Happy Holy Days
TCR-1 w 219b 3000k :heart_eyes:
FWIW, mine uses about 20 mA at the lowest visible firefly level… like when it’s so dim it’s barely even visible with fully-adjusted night vision while pointed directly at the eye point-blank. It’s like 0.0001 lumens. With a common 650mAh 16340 cell, this would last for about 1.3 days… or with a 1150mAh 18350 cell it’d be about 2.4 days.
For comparison, an Emisar D4 generally runs at about 1.7 mA on moon (~0.2 lm), which would last about 16 to 28 days on the same battery.
2.4 days
thanks for your help with the math
I ain’t smart enough to understand all that stuff, but I know why I love my D4 even more. I jusss don’t unnastand it all. Kinda like luv ain’t it?
Really I do appreciate all the work you folks do for these lights we enjoy. Seriously Toykepper etc. I truly appreciate it from the wheels of my wheelchair.
David
The math wasn’t wrong. My RRT01 just apparently uses twice as much power on firefly, compared to djozz’s RRT01. So it has half the runtime.
my personal test showed my RRT-01 died in 3 days when left on 24/7 on firefly (nightlight) use.
I think we all agree that once the RRT-01 is ON, the drain is much higher than when it is in Standby
not a problem, since I learned not to use the RRT-01 as a nightlight. In standby the parasitic drain lasts more than 2 years. In my normal use pattern I recharge long before the parasitic drain could kill a cell.
on low
and pwm
How common is it for 2019/2020 RRT01s to flicker on low levels? Is this an issue with both stock lights and modded lights?
short answer:
I think it is common for there to be visible flicker, if I look very closely, in all the 2019 and 2020 drivers.
long answer:
I tried to eliminate the flicker in one of my lights that had a 2020 driver, by trying different LEDs. It made no difference
stock XM-L, sw45k, sw30, 519a 4500K, they all flickered w a 2020 driver
I swapped in a 2019 driver… it made no difference, still flickered
I asked a couple of modder friends about their RRT-01 lights. the ones w 2019 and 2020 drivers… all flicker. The combined total of lights that flicker is about a dozen.
our drivers that do not flicker are from 2011 and 2012, a sample of about 5 lights.
I have not seen this documented anywhere, these are just my own personal observations and those of a couple people I know.
some driver feture change history:
1. the original 2011 driver has no strobe. Initially rated 500 lumens, later models 600 lumens. I believe the output increase was due solely to a change in LED model.
2. the 2012 driver adds strobe, it was used in some RRT-01, also in the NiteEye Eye10, and in the Jetbeam TCR-1 (the titanium RRT-01). These were still claimed 600 lumen on packaging. (and I find that is ballpark accurate on my homebrew meter)
3. The 2019 driver output claim writen on the packaging is 950 lumens (they tend to test a bit lower). I believe the increase is due to a component change in the driver. 2019 drivers also have strobe, like the 2012 driver. The 2019 host is a redesign, with a heavy brass pill, but the drivers are still the same size and interchangeable w 2011 and 2012 drivers.
4. The 2020 driver adds a tailswitch (no tailswitch on the earlier models), and a thermal step down component to the driver (still claimed 950 lumens on the package, like the 2019 driver, and still has strobe like 2012). The 2020 host is a redesign, the control ring gets a lubrication hole so no disassembly is required. The drivers are still the same size and interchageable with earlier models.
we can still buy 2019 and 2020 drivers, but not the 2011 nor 2012 drivers
in this pic left to right Niteye Eye10, 2011 RRT-01, TCR-1, Niteye Eye10
in this pic is the Niteye Eye10 TiC on left, the Ti version of the Niteye Eye10:
the Niteye models have fins on the head, in the case of the Eye10 TiC, they are factory drilled and tritted
l-r Sunwayman V10r Ti, Niteye Eye10 TiC, Jetbeam TCR-1, Russtang EX10 Ti:
fwiw, the Sunwayman V10r Ti, on left, does not flicker, nor do the aluminium version, the V11r.
Sunwayman drivers are different than the Jetbeam/Niteye drivers, not interchangeable. The Sunwaymans use a tailswitch.
My only 2019 RRT01 doesn’t flicker, neither before nor after modding.
just to admit when Im mistaken, and confused
Im having trouble showing flicker in a video of this 2020 driver. Not sure why:
[video: 519a dd sn45 w 2020 driver, flicker not obvious - YouTube ]
here is what the Opple sees:
otoh, here is a video of a 2020 driver that does show obvious flicker:
[video: sw45k 2020 driver flicker - YouTube ]
and what the Opple sees:
fwiw, I tried swapping the batteries in the two lights in the videos… It did not make a difference, the sw45k w 2020 driver flickered obviously with both batteries, and the 519a w 2020 driver I could not see obvious flicker w either battery.
Yeah, the opple can’t see anything because the pulsing is of low frequency and disappears on anything higher than moon mode like power. I was able to catch it once, and it’s a rectangular signal modulated on the ripple.
My 2012 RRT01 is the only light that does this. My EYE10 is ok, too. But my statistics is small. Exactly 1.
Update, I made mistakes, and edited out incorrect driver year info, in the above 2 video posts
The light that has the sw45k, and flickers, actually has a 2020 driver:
the light that has the DD 519a and that I cant see flicker atm, but did in the past, also has a 2020 driver:
2011, 2019, 2020 drivers:
the pics of the drivers installed in the lights only required me to remove the driver retaining ring, no unsoldering.
Here is a 2011 driver w sw45k, no flicker I can see:
[video: sw45k w 2011 driver - YouTube ]
and the installed 2011 driver pic:
I dont have any RRT-01 w 2019 driver installed atm… I hope others will share info if they do have a 2019 driver in an RRT-01. I do believe Unheard sees no flicker in his 2019 driver… More data points invited.
Thanks for the detailed information. I have a 2020 RRT01 here that was already modded and flickers badly on low levels, and I also couldn’t get it to register on an Opple. The burning question for me here is whether most flickering RRT01s came that way from the factory or developed the flicker after being modded. I don’t want to disassemble the light I have here, but I’d be very curious to know if flickering drivers continue to flicker when operated outside the body with everything carefully isolated.
Jon, do you have any high quality photos of all 4 sides of an RRT01 driver disassembled?
Did your RRT01 start flickering again after the LED lead repair?
yes, thanks for asking…
but only for the 2011 driver model
courtesy of geforce73, originally posted in this thread
https://www.reddit.com/r/flashlight/comments/10jggei/nmd_jetbeam_rrt01_rayten_3v_5050_4500k_4750k_bin
also stored at the end of this RRT-01 album: OG 2011 Jetbeam RRT-01 - Album on Imgur
I will also post them here:
you can see the date 20111205
these are the bottom (battery side), and top (led side)
these are the insides of the sandwich:
I have a modded tcr1 with 2019 driver without any flicker.
Great to hear!
excellent info, thanks!
based on the Two first hand reports of No Flicker w 2019 driver from Unheard and Geuzz, I suggest you order a 2019 driver from
info at jetbeamlight.com
