Sofirn SC31 PRO, New Anduril Flashlight
its worse then any fenix light i own by a significant margin. ok if its normal, just wanted to check.
Are any of those as small, and SMO? I just compared to one I had around - an old Eagle Eye X5, and roughly the same. From my collection, I'd say the OP in this size is more popular, but then you sacrifice some throw - classic tradeoff though between better looking beam on a white wall vs. better throw.
I added some DC fix for a while on mine. Smoothed out the beam but it does restrict the throw. Took it off eventually. Outside the sc31 pro looks ok.
99% of fenix are smooth, my ld 22 is almost identical in size, with 0 halo. when the light is on turbo outside, that outer ring is impressively bright. the fenix’s tend to have a deeper reflector though, this is more shallow, but i just checked a couple headlamps, and there is a dim halo, just not that bright outer edge.
Deeper reflectors will tend to tighten up the hot spot, make it more distinct, doesn't effect the actual distance much though. All my small Convoy's single LED's seem to have OP. I have a Sofirn SP32A V2.0 w/SMO, deeper reflector and it looks awful, but that's because of the XP-L2 LED with it's yellow halo. The 5000K SST-40 is so much better.
That LD22 shows here an XP-G2 - different entirely, much smaller LED surface, different profile, and of course much lower output.
Has anyone noticed high parasitic drain on a recent batch of SC31 Pro’s?
https://www.reddit.com/r/flashlight/comments/qe9ern/sofirn_sc31_pro_draining_batteries_without_use/
Sofirn kindly sent me an SC31 Pro for free that someone had returned as faulty to Amazon Australia.
I factory reset it. The Sofirn 18650 cell was 0.6V (measured with DMM).
I inserted a Samsung 30Q 4.17V and the torch works.
But I measured 250mA parasitic drain while the switch LED was off.
It has a burnt electronics smell near the head.
ordered one in november, from ali. seems to work fine, no smell, i leave the light on, its been on a week.
mine was ordered in november. 45 micro amps (not mA, that showed around . 04) with switch light off
Here are some photos of the driver:
you realized its burned right? im not sure since you didn’t say anything but that black stuff is a failed component.
Inductor exploded? Worth getting a cheap hot air station and finding a replacement part? :student:
looks burned, badly. at 22 dollars, I honestly would say no, But I have a hot air station, so its up to you, does great heat shrinking as well :slight_smile:
They may sell the driver boards separately on ali.
Yeeeeeah, something tells me that’s not normal.
Unseat, jiggle, reseat all rings, drivers, etc.? Maybe something’s pushing on something that’s at least partly shorting out.
Is the switch frame glued?
Hello guys,
I purchased two SC31 Pro’s back in August of 2020. One of them is still 100% OK as good as new, except for some normal wear of the anodization. The other one is still working OK, but the button LED is dead.
Recently I purchased SC21 Pro. This is a great little flashlight. It’s still Andúril 1 though. I have a plan to Reflash Andúril 2.0 :sunglasses::sunglasses:.
After years of using SC31 Pro my main preferences for EDC flashlight : Andúril, button-LED, magnetic tail cap. And integrated USB-C charging.
I also have a Wurkkos TS10, Andúril 2.0 :+1::+1::+1:.
It doesn’t have button-LED but the Aux LEDs are great as locator. And the tail switch is so fun and tactile.
Thanks Sofirn and Wurkkos for your great flashlights.
I also have a Sofirn HS10 , a fun little head lamp. I really like the integrated USB-C charging.
Is the new SC31 Pro better than the old version?
(with Andúril 2.0, attiny1616, exposed flashing pad)
Is it compatible with USB-C to USB-C charging? The old one can only be charged with USB-A to USB-C.
Can’t say about that BLF-L, but as noted on another thread, under $18 WITH battery, is an insane deal and a BLF superstar for what it is/price performance. I love this light and just bought 2 more. Link here: https://www.aliexpress.us/item/3256804979640708.html?spm=a2g0o.productlist.main.1.4344482aVfMs6i&algo_pvid=c9040068-256e-45db-8038-ad8e19ee56be&algo_exp_id=c9040068-256e-45db-8038-ad8e19ee56be-0&pdp_npi=4%40dis%21USD%2156.74%2117.59%21%21%2156.74%21%21%402101f49317048531900396133eea9e%2112000031941446470%21sea%21US%21799170465%21&curPageLogUid=rI5bDKoqj3C1&utparam-url=scene%3Asearch%7Cquery_from%3A
Yes, they now have T1616 and flashing pads:
I was looking at the SC31T, which is just $13 USD (with battery), but for $5 USD more to get Anduril in the SC31 Pro? No brainer, IMHO. Unless of course, you want a non-Anduril flashlight for a muggle. :wink:
I think the 2 switches on the SC31T might be confusing for a Muggle.
I think the SC18 would be a cheaper and better choice for a Muggle.
I currently have 4 SC31 Pro, one of which I will be turning into a Triple.
Interesting. Is the diameter about the same as an FW3A? Are you leveraging an existing MCPCB for the mod? Is it a conversion others have already done?
