Led4power.com : LD-4 CC linear drivers, ILC-0/1 illuminated tailcaps, optics, MOSX, copper DTP MCPCBs...
I’m not sure what is going on with this particular board, but when I have shorts after reflow, I re-heat the board and one by one slide leds off sideways with fine tweezers and then slide them in postion again. That helps removing solder bridges.
Edit: if this is a MosX board it is more surprising even: none of the solder pads should be connected to the core, even not the thermal pads. In that case you may have a defective board where somewhere the +pads are connected to the core. Can you see any dents that could have caused that?
I’ve done that, no luck.
They aren’t, they are connected to the + pad. This whole undertaking has been an exercise in frustration, I have no idea why the LEDs don’t work. Looking at it through a magnifying glass I get the impression that the pads for the LEDs don’t align well with the LEDs themselves at all but I don’t have a short between the + and - pad so that’s probably not it either. The website says the boards can be used without the MOSFET but recommends shorting the footprint in that case, but that just creates a short between + and - so I’m not sure what’s up with that.
By now I’ve probably reflowed some of the LEDs 10 or 15 times. These aren’t even reliable anymore. I think I’ll just abandon the project.
Has anyone successfully used one of the 4x4040 mosX boards?
Im not sure if this helps but I guess I used on in my OL contest build in 2019.
Check the photos here:
I am not sure if I have more with details, but I will check my G. Photos!
EDIT:
Thanks! Yeah, I definitely was unable to get t anything to light up in that configuration.
I have one in use. I had to solder LED+ to the pad that the mosfet would be on, iirc.
Important note to customers:
there is a final extra 10% discount for everything in store (code L4P2021) and it's valid until 29.12.2021.
Currently all items in store are bought and sold over my first smaller company, which I will close on 31.12.2021., and switch my business to 2nd LTD company (which I've used for lager customers and some other work).
Because I cannot mix parts bought over 1st company with stock of 2nd company, everything you see in store except for Osram LEDs is available only until 29.12.2021.
This includes LD-x4 drivers too - so they'll have obsolete/end of life status. I will not make and sell them over my LTD company, maybe if some larger buyer still needs them, 100+pcs will be min. order, but this is also questionable and depends on chips availability.
That also means there will be a gap regarding drivers availability until new driver generation is ready (and that depends a lot on chips availability, which is terrible currently).
So After New Year things that will be available are new 3030,3535,4040 16 and 20mm DTP PCBs (refreshed design), Osram CSLNM1.TG, CSLPM1.TG and CULNM1.TG, and limited qty of Luminus SFT-40.
Over time I'll add some more items in stock.
Good news is that bare LEDs will be available too, and every item will have better, more aggressive price breaks for larger quantity.
Shipping to UK without 135GBP min. order should be available too.
Orders made until 29.12.2021 which contain driver may be shipped with some delay, because I don't have lot of parts for drivers left, so it will take some time (5-7 days) until parts arrive.
Thank you for your support and I wish you happy Holidays and better New Year!
Do you have any remaining 4xV MCPCBs?
I’d like to build a quad Luxeon MZ but see that the 4 emitter + MCPCB combination is out of stock.
https://led4power.com/product/mosled-extreme-mosx-ceramic-insulation-4xv-4040-quad-mcpcb-20mm/
MZ LEDs are sold out.
Coming home soon and going to check what i still need before the end of the year.
Order placed :wink:
I’ll be looking for some goodies to start the year with some mods :wink:
Thanks for the coupon and the materials and I wish you luck in advance for the “new” store :wink: I hope we can still buy from it as small customers :innocent: :partying_face:
Would it be too much to ask if I suggested that all the out of stock products be removed? Or maybe anything still in stock consolidated into a new category?
Happy holidays and a happy New Year to you, Neven!
I don’t need any drivers at the moment but I sure hope you will bring them back sometime in the new company…very much enjoy the ones I have from you! Wish you much success with the new company also and hopefully it will prevent the past headaches with bureaucracy. :slight_smile:
Since this final sale will last for just few more days, I'll leave it as is.
+1 :+1:
I also enjoy your drivers. They are the best and I could easily say they are the beast :wink:
Note: shop will be closed in about 12 hours.
Thanks for the info. So you have an idea when drivers availability may be brought back?
I just don’t know how much reserve should I make…
As I said previously, I will not make LD-4 anymore (maybe if there is custom order with larger qty - maybe).
Yes, but I refer to:
Is it totally uknown? Or you set yourself a deadline for acomplishing the new development this way or another?
It's really hard to tell when new drivers will be available, especially now when chip sourcing is huge problem.
Fair enough. That is the case for a lot of things across many industries
