Thorfire says it starts in moonlight mode…, is a good price…but Amazon says not available! …Google not bringing up any options either.
Any one have a ThorFire PF04 they will sell?
Ultratac A3 is 3 mode, starts in low and no blinky’s. There are a few Chinese sellers on Ebay that have them. Same style and size as the IYP.
I have three of them, one with a nichia in it, one with a red led in it and one with a UV emitter in it. They are great little lights. I tried the IYP’s and the didn’t care for the modes sequence. Lumintop always screws up good lights with mode memory or dumb starts in high or medium. I swore off Lumintop.
Hey, thanks
Nothing showing on EBay or Amazon UK
Will keep a search on eBay
Thanks
It does look the ideal one
In case you don’t know there is a sub-forum dedicated to multiple AAA lights which would help focus your search.
You can get to it through the ‘Forum Categories’ sub-menu listed under the Main Menu (top left of my browser page, don’t know where it is on yours )
but here is a direct link: https://budgetlightforum.com/forum/flashlights/multipleaaa
In the first post of the first thread buck91 mentions a Nitecore MT06MD which might suit your needs?
Available here as an example only as i’ve never used the site, it was just early in the Google search results:
https://www.nitecore.co.uk/Shop/Torches/MT-Series/13533-Nitecore-MT06MD.html
I’ve owned a couple of Thorfire PF04s, and unfortunately while they satisfy your other requirements, they do have mode memory (and are discontinued now).
However, here’s something that should perfectly fit your requirements: Wurkkos WK02
- 2 x AAA
- 3 modes (Low, Medium, High)
- Starts on Low
- High CRI
Thanks about sub forum…missed that…
the MT06MD is one I already have in my shopping cart from Torch direct
https://www.torchdirect.co.uk/led-hand-torches/nitecore-mt06md-penlight-led-torch.html
thanks again
nice thanks
I second Serlite’s suggestion of Wurkkos WK02. I quite like mine, and it’s one of only two lights I’ve been sent for review that I’ve kept after the review has been finished.
ok , thanks
have some good pointers there.
Thank you
Three of these Nitecore MT06MD’s ordered
For the record, I found out that the Nicron N73 is apparently available on Ebay ; using the keyword “Nicron Twist 90° Magnetic LED Flashlight”. Multiple vendors will show up. I’m thinking of getting one for myself.
PS : as suggested, mods should move this thread in the Multiple AAA subforum.
Wurkkos WK02 (and WK01) for $8.99, while they last.
The Wurkkos WK02 is a fantastic 2xAAA. They are also on clearance right now for $8.99 on Wurkkos.com. High CRI choices, too and multiple colors.
Nice, thanks
The Nitecores we did buy do the job just great for now though.
Might order one of these though
I have a Nitecore MT06MD. It always turns on low (4 lumens floody), then half presses for medium and high. The button is mushy.
Unless you need high CRI, I prefer the single mode Streamlight stylus or the brighter Mac Tools 2xAAA. If you aren’t set on 2xAAA, I would take my Microstream USB over any of these, but the low is 50 lumens.
You might also consider a single AA flashlight. My favorite is the EagTac Clicky. It has a tail switch, and if the head is tight it comes on high, if the head is loose it’s in mode memory which you could keep on low… that’s how I use it.
I had not looked at the actual Nitecore low level figure, but we have found it to be a little bright actually. We would have preferred if the First On low click was actually a little lower.
When it comes on in a night time darkened Ambo aircraft cockpit or in the cabin with the medical team, it had been commented that it is a bit too bright.
AAA is the ideal size as it fits in to the pen pockets of paramedic / flight crew flight suits.
A bonus of them that we were not originally aware of is they can be sterilised. Not of interest to us as the flight crew, but the medical guys might find that handy.
The button is a let down though, it does occasionally feel a bit stiff.
I have already e-mailed Nitecore with regard to the button and brightness issues.
I don’t know how well it would work for sanitization, but one mod I tried on a couple flashlights was to use “privacy film” you can pick up at HD or similar. It’s the film that you put on bathroom windows or front/back doors so people can’t see directly through. It will make the beam more floody, and a thick frost should cut down on the brightness 10–25. I use DC fix, but usually look for more light transmitance, so the inefficiencies from the generic version should work in your favor. IMO, get the one with a sticky side to make it a quick mod.
Back when I was younger, the hospital would sometimes have this plastic-y translucent tape. In a pinch, you could just slap that on the head.
Although I don’t like the button, the idea is to turn the flashlight on with a click (low). Then half press to cycle the modes while on. If you try to do it quickly it is more annoying. Just turn it on as a first step. Take a breath, then half press if you want a higher mode. This slows down the process of changing modes, but keeps me from tearing my hair out trying to get it to to med or high by rushing.
I’ve received the WK02 and WK01, both in red. They seem great… the 01 isn’t as small as the Tool that I’ve misplaced.
Can you confirm that they do always come on in Bright first? and you must cycle down too Low…or can yo set it to memory mode so it always starts in Low
they look great if they can start in Low
