So is the flash-to-off quirk a widespread issue or not? I have yet to see it on mine and I’ve been using it nearly every evening since I got it.
I have another niggle….this light is a PITA for tail standing. I was commenting in someone else’s thread (tactical grizzly maybe) where they said it tail stands well. I find that the surface needs to be flat-flat and pretty sturdy or else this light is liable to topple over. I sat it on an old pc box and it kept falling over….got out an angle gauge and it was about 4.5°. lol. There’s only something like 30% of the circumference that is a footprint for contact - they took way too much material away. If they come out with a green magnetic cap I’ll pick that up. For now, I put the Convoy T2 16mm ring magnet back in it…sticks up a little above the ears so it’s at risk for fracture but it helps the light tail stand properly.
Other than that I like this light a lot. Picked up some brass tubing 9.5mm x 1mm and will slice off some button washers soon.
Try turning it off from level 2 out of 7, stepped ramp, advanced mode with a 14500 inside. The stepping down before off bug was reproducible that way, but I have only seen the flash once or twice before I fixed it with a firmware update.
Well…there it is! Happened on a fresh 14500 as well as NiMH. In stepped mode I could only get it to happen on that low 2nd step…everything else was normal. Playing with quick successive power cycles, the behavior varied a lot in both delay and duration…and one time I got the super bright flash. Man that’s an irritating surprise when you’re in a low lumen state of mind! lol. With the light on that second step and then switching to ramping, it did the same thing. Bumped it up the ramp as little/quickly as I could and the next increment behaved the same, the one after that was intermittent. I also noticed a little bit of flutter on the down ramp in that lighting range…don’t see it on the up ramp, though. Weird.
I normally use this light at levels higher than this range-of-quirkiness so I don’t think I’ll bother flashing the firmware although I still want to learn that sometime soon.
Here are some white wall beam shots of SP10 compared with my other lights. White balance was manually set at 5000K. CIE x and y numbers are from Opple Light Master and duv are calculated online
Figure 1. Sofirn SP10 Pro LH351D 5000K vs BLF-348 Nichia 219c 5000K
Figure 2. Sofirn SP10 Pro LH351D 5000K vs Noctigon KR4 Nichia E21A 5000K
The measurements are as follows:
CIE x=0.3546 y=0.3646
duv=0.0028
I prefer lights with CCT of 5000K. This is my first time with LH351D. I am a little disappointed with its tint. Calculated duv appears to be fine, but when I shine the light on my skin, my skin appears to be show too much yellow and green.
I agree, and I think it is because the CRI R9 is not very high…
Excellent compariso photos, and very helpful to have some Opple DUV values for reference.
fwiw, learning to swap LEDs is a game changer. Here is an SP10 Pro album with DUV values: Sofirn SP10 PRO LED swap - Album on Imgur and photos of the modding sequence.
here is a summary of the DUV changes:
fwiw, the 519a shows really good skin tones, and the High R9 really makes reds Pop, even when the tint is above the BBL… much better than LH351d, which makes weak reds, and as you noted, poor skin tones.
Thanks for that data… I have 573’s, 503’s and 453’s on hand, does not seem to be a linear change looking at the results of your 573 dropping 1700k and the 453 only dropped 1100k. So, I am guessing that the 503 will drop to slightly below 4000-3800k. I think I will go a de-domed 573.
