He only dips the bezel part. That’s my method also. First whole head of light to freezer to shrink. Then just quick dip of bezel to boiling water. Bezel expanses when rest of the head is still shrinken.
I also use the boiling water method but the parts are in a plastic bag when they are dipped in the water. I’m pretty sure jon_slider also uses this method.
So its done.Sofirn Sc32 reflowed with xhp50.2.Its a little pocket rocket.Interesting that the optic is fit with xhp as it was fit with the original sst40.And the size is pretty different.Shines brutally good.Hot on turbo after 15 seconds but its the smallest xhp50 torch i know about…Maybe any Eagletac model.But this is pretty small.10 cm…Nice model really small and bright.Now a hot rod.Sadly i dont know how to post pics here.Iam in the forest.And its briiight
I did my first spring bypass on a BLF Q8. The soldering isn’t the prettiest, but all of the joints are solid enough. I scraped some of the solder mask off the traces on the bottom board near the screw holes and soldered the bypass wires to those.
I definitely didn't even want to attempt it out of fear of failure (and ruining the light), but it came out pretty good. I had hit some bumps along the way like needing to make my own 1.5mm wires to extend the leads from the driver bc they wouldn't reach my reground 16mm mcpcb pads. I also had to use a centering ring i had luckily left over form a GT Micro mod.
A huge thank you to JonSlider for showing me the way on how to even get this light apart, and for leading me to the Amazing CRX mods on what the MCPCB needed to look like! Thank you Jon, and CRX too! My mcpcb doesn't look anywhere near as clean as theirs do, but I tried my best! the light works and the tint... well, a dedomed sm405 Nichia 519a, it looks amazing of course!
Thank you! I had not planned on being successful, so when I was I was quite happy lol. All in all I guess it wasn't a terrible mod, but since it wasn't my light and I have no idea how hard these are to replace it I broke it, the tension was high lol. I'm glad it worked out tho. It's acrually a really nice light I would've never given a second look unless I handled one. I think I may try to find one to mod for myself.
Nice job Scalleywag! I just recieved and modded my first Unicorn last week. I tried putting 519a in and running Panasonic GA 3500mah, and i got a decrease in output and High CCT on turbo, so i went xpl-hi in the end. I have noticed that with a lot of lights like the Olight warrior mini original, the Sofirn TS21, and some more. But i was surprised the Unicorn was pushing too many amps for the 519a. or i am doing something wrong?
What thefreeman said. It’s fully regulated. Could the reflows be bad, or something wrong with the LEDs?
Come to think of it, you do a lot of modding over on Reddit, I’d be pretty surprised if you were getting bad reflows…
The TS21 has full-FET and bad heatsinking, so that one doesn’t surprise me at all - “angry blue” as we call it. Not familiar with Warrior Pro’s driver but Olight is known for good regulated drivers in general
