AceBeam X80GT 2 34000LM 6500K EDC LED Flashlight w/4*18650 Batteries
Authentic / 18*Cree XHP50.3 emitters / 16-mode / IPX8 (30m underwater) / 498m throw / 61900cd
Details:
Power Mode:
Low: 220lms, 34hours, 47meters, 550cd;
Med1: 1,250lms, 7hours, 95meters, 2,770cd;
Med2: 2,000lms, 3.5hours, 124meters, 3,850cd;
Med3: 4,100lms, 2hours, 160meters, 6,365cd;
High: 9,400lms-4,300lms, 4minutes + 1.5hours, 242meters, 16,400cd;
Turbo: 17,800lms-4,300lms, 2minutes + 1.5hours, 329meters, 27,000cd;
Turbo Max: 34,000lms-4,300lms, 1minute + 1.25hours, 498meters, 61,900cd;
Strobe: 4,100lms, 3.5 hours;
ECO Mode:
Med1: 1,000lms, 8.5hours, 85meters, 1,800cd;
Med2: 2,000lms, 4hours, 124meters, 3,350cd;
Med3: 3,200lms, 3hours, 144meters, 5,200cd;
High: 6,800lms-3,000lms, 6minutes + 2.5hours, 207meters, 10,700cd;
Turbo: 13,000lms-3,000lms, 4minutes + 2.25hours, 285meters,20,300cd;
Turbo Max: 21,000lms-3,000lms, 2minutes + 2 hours; 382meters, 36,500cd;
Strobe: 4,000lms, 3.5 hours;
18*Cree XHP50.3 LEDs with a lifespan of 50,000 hours;
Max 34,000 lumens output by using 4*18650 3100mAh AceBeam High Drain rechargeable batteries;
Working voltage: 10V to 16.8V;
Head diameter: 65mm
Tube diameter: 49mm
Max beam distance: 498 meters;
Impact resistant: 1.2 meters;
Underwater 30 meters (The X80 GT2 is the most durable flashlight yet produced by AceBeam, capable of surviving accidental immersion to extreme depths of up to 30 meters! However, it is not a diving light, and should not be turned on or off underwater.);
Aircraft grade aluminum body structure;
Premium type III hard-anodized anti-abrasive finish;
Ultra-clear tempered glass lens with anti-reflective coating, which achieves a 98.3% light transmittance;
Strobe mode for tactical and emergency use;
Smooth reflector for max light output;
Highly focused beam for maximum distance;
Tactical knurling for firm grip;
Streamlined body design;
Intelligent highly efficient circuit board design for max performance and long run time;
Intelligent temperature controlled light output for user safety;
Specially designed for tactical, Law Enforcement, Self-defense, Hunting, Search & Rescue, and outdoor activities;
Onboard UNC1/4” thread with D-screw hook, easy mount to standard tripod, handle, and lanyard;
The tripod interface can be conveniently connected to the tripod and used as a fill light for photography.
Please note this flashlight will become very hot at maximum output and must be carefully handled to avoid burns. Furthermore, the extreme output can cause injury to human or animal eyes - please do not look at the lens while activating or directing the beam towards any person or animal. This flashlight must be kept out of the reach of children.
