IPX-7 is defined as “continous immersion up to 1 m for 30 minutes”. Not to mention that it is a “static” rating in that the light is not moved or switched on/off during the test. At least it’s a set standard.
IPX-8 is defined as “equal to and greater than IPX-7 in some way”, ” continous immersion beyond 1 m” AND under conditions which are identified by the manufacturer The specs vary from manufacturer to manufacturer. Almost meaningless. An IPX-8 light could be any light capable of submersion to 1 m for 31 minutes. Also a “static” rating.
I like specs and ratings but sometimes they can be misleading.
BTW!!!
if well make a group to buy this torch. the minimum for getting directly through the factory in 10 pcs…
and payment can be made via paypal… maybe they can give us a better price??
I’m not doubting what they say (well, a little) but I am curious about how they tested it. Apparently there is no real standard beyond IPX-7 and we must rely on the maker’s method of testing. If they don’t tell us how they tested it then the numbers don’t mean a lot. Was it done in a pressure tank with no movement and no turning it on/off (static)? Was it done while being used the way a live diver would use it by moving it around and turning it on/off? There is a big difference between the two. There is a difference in viscosity of the water types as well. Salt vs fresh. Did they test for both? It’s the unknown stuff that I question.
It’s obviously built to be heavy duty and I like the double diameter threading and the quad seals/o-rings on each end of the light. I have not seen how the lens is mounted yet. All in all it looks to be a winner. For under $100, you should go for it.
Hi! Having done a little Scuba Diving (some at night), I would say that this looks like it might be a really, really good light. I have talked with a well-connected supplier in China and there is a possibility of a Group Buy. By the way, this supplier also has a less expensive diving light – 2x18650 with a T6 LED. It would probably be $40 or less shipped.
On the other hand, the CNQ price is pretty good on the TF TR-DF003 and Ric might consider a Group Buy as well. (I don’t know.)
About the shipping cost: Apparently the shipping weight is 1.7kg! That’s a heavy package and I don’t know what the shipping would be.
IMHO this light deserves pursuing IF there are enough people that are interested. We might even want to “pool” our resources with a diving forum in order to get the numbers up.
I’ve been wanting one of these, but the shipping from CNQ really brings the price up. For the least expensive shipping which is registered shipping is $28.96 and DHL is $32.00. Those shipping costs are so close, it just makes more sense to go with DHL and have it in a week or less once shipped.
I also would prefer getting the complete package with the good Trustfire 5000mAh batteries, but I’ll go along with what the rest do if a group buy gets going.
Hi Richie! Just curious - where did you find the $28.96 price? About DHL, one of my China contacts has a good deal with them and he actually pays less for shipments over 2kg via DHL than with ordinary China Air.
Please keep in mind however that this is a true Diving Light and VERY heavy
ABOUT THE PRICE: IMHO, $40 is wishful thinking. In fact, if a seller quoted that, I’d totally suspect a scam. Nevertheless, a product of this apparent quality would go for several hundred dollars at a Dive Shop. The only caveat is that most well thought of Dive Lights have a pistol grip or a wrist strap. Nevertheless, I could join a couple of Dive Forums and mention the idea of joining our Group Buy – just to increase the numbers.
Also, keep in mind that this seems to be a really great normal light as well. It certainly has enough mass to dissipate a lot of heat above the water. I’m probably not telling you anything new but single purpose, dedicated dive lights don’t need to handle so much heat because the water keeps them cool.
I added the light to the cart and then started the check-out process and it brings up all the shipping options. $28.96 is the cheapest CNQ will ship this light. I still want the light, just looking for the best price from a good seller.
You should better move here to france. Out of all the packages I ever received so far, I payed taxes only for one of them. For the most expensive item I’ve got recently I payed over 200 USD and that one was also not taxed. Btw, I live not far away from you. Down the A5 to Weil and then about 15 minutes over smaller roads.
