Got my HD2010 from Tmart today. The usual nicks and dings in the finish that others have mentioned. At least with the light grey finish they aren’t quite as obvious. The reflector on my copy seems good with no marks or scratches and it’s quite clean. There was no insulator between the back of the reflector and the wires to the LED, so tightening the bezel caused a predictable short.
One o-ring broke while taking the light apart but they are all crappy thin ones and will be replaced anyway. Tail cap was tight but had a bit of flicker when shaking the light. Tightening the pill into the head fixed it. No lube anywhere on the light.
Massively built - it feels heavy in my hand. Not much brighter than my KD C8 on a ceiling bounce, but boy does it ever throw the light down range. This is my first thrower, so I have little to compare it to. But it lit up a large building quite well at 167 metres. This was in a city park surrounded by street lights so it would be even better in full darkness. Can’t wait to get down by the river with a fully charged batt.
Has anyone found nice black ones without any marks on the finish?
I ordered the Ultrafire HD-2010 from tmart.com, and just got it in the mail today. Is it supposed to have “Ultrafire” etched on the side as all the pictures of reviews show? Because mine doesn’t. And now I’m confused :~
TMart for mine as well. I just received a second gray model, I prefer this color to black. The second one had a minor defect, the o-ring on the cap was broken, but it functioned fine.
Which color did you order? I ordered from Tmart the black color one just because I read alot of posts where the gray ones were nicked. Mine had one slight nick and had the Ultrafire printed on the body. Good purchase, good thrower.
my gray light from tmart arrived in only 2 days and is in immaculate condition…no nicks in the finish, no nicks in reflector, emitter is centered, no ugly colors in emitted… too thumbs up!
I have two HD2010's. The first one was a TangsFire that would not pull 3 amps at the tailcap and the latest one from Tmart USA is an UltraFire that pulls over 4.5 amps at the tailcap. The drivers appear identical. The only real difference looking at the two is that the UltraFire is more of a gloss black and the reflector while looking at it appears shiny, when the flashlight is on the reflector appears misty. I have tried washing it gently with detergent and hot water but did not clean up at all.
I purchased a Lightmalls Ultrafire HD2010, and boy does it perform. It pulls 4.6A at the tail on high (King Kong 26650), and does not have a single scratch on the body or the reflector. Nice threads also.
I highly recommend the lightmalls HD2010. It says it is rated at 600lm, but it actually puts out a lot more!
On one slat it kinda sez….‘HWA/HX(K?)S, UltraFire, HD2010”. I can’t tell for sure. Thing is the lettering looks like a restrike or something because you’re definitely seeing ’double’. lol
Other slat sez, ‘CREE XM-LT6’. This slat’s lettering is ok. Besides the funky print it works aces so far. Had to clean real good though with CRC 2-26 before it would function right. Else this sucka would’ve gone RMA.
