LOL that list is for not search every time you suggest something :bigsmile: Well, almost all lights are in my price range and preferences. Difficul to choose, but I hope that with your help I will discard more of them ;)
Hi, Langcjl. Thanks for the reply. Yeah, could be a nice choice. 7.99+16,40=$24,39 :D The only thing... from reviews, looks like I will need a good AR coated lenses for that body. Good P60 host with good heat-sinking.
UPDATE: what about regulation? Is it good on that drop-in?
My vote is for this manafont T6 drop-in and the solarforce host of your choice. The drop-in from manafont is one of the nicest and brightest out there right now, and fits all of your criteria (3mode with memory, no strobes). Plus, with the solarforce you get the flexability of swapping out the drop-in as easily as swapping batteries. Bonus points if you get the AR lens.
Really hard to go wrong with that set-up.
Thanks, Match. So you recommed body+dropin? Well, thinking better, it's a good choice, because you can buy another dropin later and swap them and I have to admit that this dropin is the best for me: no party modes, memory and a SMO reflector for a better throw :D Does SF bodies comes with AR coated lenses? Anybody knows that? And comparing MF dropin to SF dropin?
Best bet on an AR lens is to get one from KD for ~$2. As far as differences between MF and SF drop-in:
-No party modes on the MF drop-in
-MF drop-in will be a hell of a lot brighter. The SF drop-in is run at reduced current whereas the MF drop-in will give you an honest 3A.
There is no point in buying an L2P from USA if you are located in Europe, buy from HK, cheaper and faster.
You should improve the heatsinking with aluminium strips (better than foil), but you still won't have good enough heatsinking to run it on full for extended periods of time (unless maybe if using it outside when it's very cold).
I have two Solarforce drop-ins (not XM-L though) and both are rather crappy, so I wouldn't bother with them.
+1
But i would also consider the skyray body at 7,99 which is very nicely made if you happen to like the looks.
Would also pay the 2usd worth of multilayer coard lens from KD.
I have that setup (actually have two, the other is the infamous 504B new style that i happen to like alot)
Both KD lensed and manafont 3 H-M-L dropin with SMO reflector.
You can't go wrong. The genuine solarforce L2(xy) are probably the best budget P60 hosts. Comes at a bit highr price. I have clones and one genuine to compare. If you're not picky both work the same way but you can feel the genuine solarforce is better made.
If you get the Solarforce L2i, do you still need the lens from KD?
It's not a really a need but it's kinda "pimp my torch" category. A 8-12% more light transmittance was mesured by those who swapped generic lenses for those. I consider it the best and easiest upgrade for cheap. Occasional users will probably not bother.
I like that, 'Pimp my Torch' category. So instead of the word mod you can say, 'hey guys, I just pimped my torch with a manafont xml'. :bigsmile:
LOL...thanks for that
:P
As someone who just ordered the MF drop in and Solarforce host last week, I'm interested in knowing what an AR lens would do for the combo, and if someone had a link to one. I've looked on KD and there are a bunch of lenses. I'm pretty new, obviously, and just trying to learn...thanks!
Dave
Dave,
Here you go....
http://www.kaidomain.com/ProductDetails.aspx?ProductId=1766
http://www.kaidomain.com/ProductDetails.aspx?ProductId=9064
This information was given to me by the guys on here. I have not ordered either lens yet but I believe several have ordered the second type but the first one would fit also. Someone please correct me if I'm wrong.
I got these and i'm not alone:
Very happy with.
I just ordered 3...thanks a lot guys...I love this forum!
Dave
Maybe this is he XM-L we should be buying
TrustFire X-Series X8 CREE XM-L T6 LED 5-Mode Aluminum Torch
Really useful this post! Me and SashiX are searching for (almost) the same light! I have a little lower budget (0-22 dollars) .
I have to thank you Sashix because you found flashlight that i don't.
I was going for DX 504 but now i have more choice. Also KD Manta ray L2 don't seems to be bad.
Two doubt..
- the difference in lumen between DX 504 (500) and KD Manta Ray (1000) is only for the board?
- One of these is more balanced between flood and thrower or are all mostly thrower?
Sorry if i use sashiX post for my questions...
Someone who has both MF dropin and C8 or J01, can you compare them? If I remember well, Don has both of them. And that Don's thread with big shots of various lights... have to find it.
Nah, Davx, no prob ;) Firstly I thought using your post would be a great idea, because as you said, we are both looking fot (almost) the same light. Created this because of wider choice. Well DX 504 is a new light, nobody have it. And that KD Manta neither, I think So dunno you will got answer shortly.
Crap, man. For $00,00 I want 10 of them... no, 50 :bigsmile:
