Tofty's Custom and Modded Lights (Section 3 updated, 17th February 14)
SECTION 4: MODS and TING
Here's the rest of the things i've done that are not complete light builds.
One of my first proper mods; an simple Aspheric Thrower using an EZ900 XR-E through the Ahorton lens and mounted into the simple Skyray P60 host.
Only the tiniest bit of cutting was needed on the host to remove the lip which usually holds the lens in place. The LED pill sits in a threaded copper tube to allow subtle adjustment relative to the lens.
More details on the build Here on Multitool.org
I got a modded triple E-series head back from Tana recently and decided to give it a e1 type body but being a high powered drop-in i wanted as much battery as i could get so i made an 18350 sized body for it.
This is my old-school pineapple build, the body is an old E-series compatible PEU Pineapple while the head and tail are my own creations (although the tail is a close facsimile of a McGizmo Aleph tailcap). My inspiration came from these pictures of previous pineapple builds by wave_particle:
I love the shape of the light in the first picture but it looks like it has a titanium head and tail and as i want to give this light a triple LED head titanium is not a sensible option and since i don't like bare aluminium, i decided to go with the red and black colour scheme of the light in the second picture.
Unfortunately while trying to remove the original anodising on the body i etched it quite badly which is why is has such a matte finish. The black body i have looks alright with the head and tail but i'll probably get another pineapple body and try again to get it anodised red. It might also have another go at making a head and tail as there are a few improvements i would implement.
I really wish i hadn't cut the text in the head but luckily it being black has made it a bit less obvious. A copper triple drop-in hasn't been made yet.
Both the e1 body and pineapple build are discussed: Here on CaramelisedPlumFritters and Here on Multitool.org
2W 445nm Blue Laser Drop-In.
This thing is just dangerous, i'm not entirely sure why i made it but it does work quite well. The bezel ring is titanium and the host is an aptly coloured Solarforce L2P. The tail has been converted to a reverse clicky as it seems like the safer option.
As thermal path is very important with laser diodes due to their low thermal operating temperature maximum i used as much copper as possible.
I designed the drop-in to be dismantleable so the leads are screwed in place and the central 12mm module removed and replaced if need be.
Pretty.
This laser build is also discussed more Here on CodPosterFactory
5mm Nichia GS Array P60 Drop-In.
It doesn't work very well but it was an interesting experiment and some features will be used on future projects.
The original build thread with more pictures can be found here.
This is my copper tail cap machined to match the copper Cryos Cool Head and copper/carbon fibre Cryos Body.
The host now has a Hit Man direct-drive LED-Tech copper mounted XML2-U2 drop-in and runs off an AW IMR 18650.
The switch is a McClicky and the bottom plate is separate from the main tail section and is retained by the bezel ring.
What to do with all those left over Solarforce parts? Build a stubby host of course.
The body section is just a cut down version of the L2 body with the full P60 cavity, although the bore is only 17mm. If someone made a 16250 cell then a standard P60 could be used but i plan to make a custom triple drop-in for the light and use it with an IMR 16340. There will be a 5mm copper puck between the MCPCB and 3A driver board.
The light is a bit longer than the Torch Lab Pocket Stubby but that's all just in the extra length of the clicky switch.
My 10 amp reverse clicky switch for Solarforce tailcaps.
This is a project to construct a higher current handling clicky switch for 6P architecture lights. The switch has been sized to fit snugly into a Solarforce S1 tailcap and be secured in place with the Solarforce aluminium retaining ring. However the basic design should be able to be altered to match the McClicky switch profile and perhaps other similar switches.
Renders of my original 'Tofty Switch 0', which has gone through a number of alterations to become the finished 'Tofty Switch 1' shown below.
A number of switches have been sent out into the community for beta testing and small scale switch production will begin soon, so long as the testing feedback does not flag up any serious problems.
The original project thread with more information can be found here.
Brass V10R heat-sinks with tritium holes.
This was a bit of a failed experiment but not entirely. Installing tritium into the heat-sinks of the Sunwayman V10R Ti and Ti+ is quite a popular mod but quite an expensive thing to get done by a professional modder. I was therefore asked by a previous client of mine whether 3D printing could allow a heat-sink to be made with tritium holes pre-formed and these are the results:
the version above is in bronze and can take 20 of the 2x6mm tritium vials. The biggest problem with this project is that the threads still need machining, which is difficult as the heat-sink itself isn't perfectly round so centering it into a lathe chuck is very difficult. I had this made in bronze as Shapeways had an discount on the material at the time but from my research i concluded that it's thermal properties are pretty awful and unsuitable for use as a heatsink, being only slightly better of thermal transfer than titanium.
The version below is in brass and can take 20 of the 2x8mm tritium vials. Although not as good as brass can be, the brass alloy Shapeways use should have reasonably good thermal properties and be suitable for heat-sink applications as a valid upgrade.
The version below is also in brass but with no tritium holes, so was designed be be as efficient a heat-sink as possible, which realistically is a bit pointless as the thermal path between the LED and heat-sink involves a lot of titanium and therefore a rather large bottle-neck.
In conclusion i realised that the hassle of having to machine parts of the printed heat-sink out-weighs any advantage gained. It would probably be easier and cheaper to completely machine a new heat-sink from brass including the drilled tritium holes.
As may be apparent i have a fair interest in the P60 drop-in format and have been collecting both hosts and drop-ins for a while now.
This picture was taken about seven months ago.... Two months ago....
And just this morning.
Now all i have to do is make a load of drop-ins for the empties.
Updates will continue until morale improves.
SECTION 5: SPECIAL MATERIALS
Firstly yes i do think titanium is a special material and my Ti Dive torch should really be here rather than Section 2.
Even so i've got a few other exotic materials in mind for various lights......
Future Projects....
Magnesium UV Torch.
This is my planned magnesium bodied torch which will use an LED Engin 365nm chip run at 700mA and will be powered by an AW Protected 18500.
the lens is a visible light filtering lens and allows only UV light to pass through. The GITD o-ring is to help identify if the torch is on and working.
The purple coloured parts will be anodised aluminium. They were originally planned to be titanium but since that would seriously offset the weight saving advantage of the magnesium i changed my mind. The reason for these non-magnesium parts was to avoid excessive wearing of the rather soft magnesium, especially on the threads used to gain access to the battery.
I actually have everything i need to start this project, including far more magnesium than i need and it will be my next major build.
The only thing i'm unsure of is how to anodise the magnesium, i got hold of a MIL document that explains the process to some extent but it's either going to be whole lot of trial and error or i get lucky and find someone with that kind of experience, fingers crossed.
Original concept thread on Multitool.org
Tungsten Torch.
Now this one's just silly, i admit it, but i'm still going to try and make it.
I've wanted to work with tungsten for quite a while now, probably just because of it's reputation. Just like titanium i suspect tungsten just needs a considered approach and the right tools.
The basic design of the light is quite similar to some of my two 16340 brass torches with the difference being that there will not be a solid core but rather a copper drop-in that screws down into the body. The LED will hopefully be a high CRI 3000k XM-L2 driven at 3A and using the good old 20mm 10003 Carclo TIR optic.
Since tungsten is so hard i've tried to design all the components to be similarly rugged; the lens is rubber mounted above, below and round it's circumference, the drop-in and optic are secured in place with locking rings, the battery is secured in place with o-rings and plastic collars and is not supported by springs, all joints are double o-ringed and the tail switch boot is shrouded. All in all it should be pretty sturdy. When it gets dropped onto a paving slab, it's the slab that will come off worse.
The anti-roll ring is a separate piece and will hopefully be made from titanium, anodised blue to add a touch of colour to what will be quite a somber piece.
All that's left to do is find some 1" bloody tungsten rod.
Wooden Clad Stainless Steel Torch.
This light is supposed to be a homage to the early Surefire weaponlight heads (Z32) and is designed to hold a P60 module.
The P60 module is planned to be a custom unit with a 26.5mm Carclo optic, an XP-C mounted to a Noctigon copper PCPCB, driven hard with a silver plated copper heat-sink.
The type of wood i've chosen for this torch is Bog Oak from the Fens.
I chose it rather than Irish bog oak because i wanted to have clearer grain definition than just the black against black of some of the more ancient bog woods.
The grain will run from top to bottom on the light rather than around as shown in the renders. The wood will be oiled but not varnished or stained as it doesn't need to be.
The torch body is made up of seven pieces not including the wood, and is all screwed together allowing the wooden pieces to be installed as single pieces rather than half that need to be glued together.
There are a few other lights that use special materials in the planning stages which will hopefully make an appearance eventually.
whew... that was tough :D
cant wait to see whats to come
edit: i think i can honestly say... ill take one of each
Speechless.
WOW… very cool lights!!!
this.
Simply amazing work! :open_mouth:
You are real maister…
There are no flashlights like hand made flashlights.
Well… I hope your journey will never end, this simply provide so much refreshing and entertaining.
Im blown away by your sheer talent and creativity. Thank you for posting!
There should be a NSFW tag in the title because this is some straight up hardcore flashlight porn.
All the above Tofty. These are all works of art. The beaten look one especially as to me at a casual glance looks like an old piece of wood. Keep em coming.
WOW!
This light is amazing. I love the organic look is has, like something grew this way, died and you made a flashlight from its petrified skeleton.
Is this there going to be a production run of this?
exactly what I was thinking! you just raised my addiction go a new level!
the 3d printed and the special materials lights are by far my favorite.
http://www.shapeways.com/model/1103655/ag-torch-ser-002-silver-parts-flashlight.html?li=productBox-search
but... will not be in my collection anytime soon :(
others of interest:
http://www.shapeways.com/shops/toftylight
Love… IT!!! :heart_eyes:
Now, that’s the good stuff! I’ve seen a few of these and been suitably impressed… new was the beaten looking one, and I like it. Thanks for sharing.
i really want to see more on the special material ones. i dont know why as i dont care for purple much, but that purple torch is calling my name
can someone pass me my jaw please?
Awesome work. Thank you for sharing.
whoa that 3d printer one is pretty mind blowing at all the possibilities. thx for sharing.
Thanks everyone, it's great to see something other than the usual indifference on a forum, especially one of such connoisseurs.
I'm off for a long weekend in a bit for a beer festival but i will answer all questions as soon as i get back, unlikely as that may sound.
Cheers.
