You have a 2x and a 3x version of the HD2010 pill, Is that the standard version has clearance for the chip on the driver as though for 2 chips…in other words a stacked chip giving 2 chips on the board will touch the copper? And a 3x version will allow room for 2 chips or touch 3?
You have those of us wanting additional room in a “2x” list, with everyone else getting the 3x? By the description 3x looks like more room. See? I’m confused.
Sorry for the confusion. The 2x AMC version has room for one additional AMC chip to be stacked on top of the default AMC7135 chip (2 in total). The 3x AMC version has room for two more AMC chips to be stacked (3 in total).
If you’re planning to use the East-92 DD driver, you’d be fine with the 2x edition.
If you have 2x AMC chips in total, you can use the 2x AMC edition pill, but I’m not sure whether it would touch the top of the pill. It would be very close, however.
I use a 17mm Qlite based on the Nanjg 105c layout, with 4 7135 chips on each side in stock form. I have been stacking a chip on each of the existing chips, 4 on each side of the board, but would like to double stack on the inside and keep the spring side clean with a single layer of chips. In that case, the chips would be 3 tall on the board.
So could I get the deeper pill please? I may end up doubling the inside, with another stack on the outside, for 20 chips total. I think the Powerizer 26650 will handle that. Want to see, at any rate!
Was looking at my HD2010 this evening, with it’s XP-G2 on a 20mm SinkPAD and 16 total chips. Was working when I first picked it up, wasn’t working moments later. The emitter will fire up with an external battery applied to the pad, but nothing through the driver. I have no idea what I could have done, but not planning on messing with it as it’s all about to be a moot point anyway! lol
Okay, then I'll still take two each of those HD2010 pills, which isn't what I originally thought they were going to be, but that's okay. Thanks for clearing that up.
Haha, you’re lucky because I shipped all the untracked packages (except for yours and one other) Friday. The tracked ones took a little bit more time so I couldn’t make it to the post office on time.
Go ahead and send the payment, I’ll add the Convoy C8 pill.
Got the PP and form, thanks. Will ship your HD2010 pill (with extra room) on Monday with the rest of the packages.
Thanks guys for your patience. The shipping rates were higher than I had anticipated, so I did lose some money especially for those with tracking, but that’s okay.
I’ll be sending out tracking codes via PM shortly.
