The last Convoy C8 has some aesthetic blemishes and thus qualifies for free untracked shipping. (Sold.)
Those who want extra room for HD2010 additional 2x AMC stacking:
1x Tom E
2x troisanh
1x LinusHofmann
1x DBCstm
1x HarleyQuin
2x crnkin
1x FmC
2x leafeye
1x scotlarock
I’ve ordered 25 3x (total) AMC edition HD2010 pills and 15 2x (total) AMC edition pills. ![]()
Let me know if you want to be on this list!
Comparison:
Taking payments:
I’m taking payments now until the stock runs out.
Please use this form to guide you through the payment process:
Please feel free to PM me or comment below if you have any questions.
Update 10/29/2013 KST:
I’ve just returned from the machine shop and put a down payment for 40 HD2010 and 30 Convoy C8 copper pills.
Here are the changes (from the samples) that are going to be applied:
-The HD2010 pill’s surface will be flat, not drilled(as seen in the photos). The positive and negative lead holes will be diagonally cut from the edges of the 17mm driver slot to the 20mm LED PCB contact plate.
-Increase the LED PCB contact plate by 1mm for the HD2010 so that the LED would be correctly focused.
-The top height of the Convoy C8 pill will be increased by 1.5mm to increase thermal mass without compromising proper assembly.
The machinist quoted 8-10 days for the preparing and machining process from today.
_
Pre-order form here now online!
Update 10/28/2013 KST:
I’ve just returned from the machine shop with samples of HD2010 and Convoy C8 pills.
They’re very hefty, as seen in the photos:
HD2010 original:
HD2010 copper:
Convoy C8 original:
Convoy C8 copper:
Here’s some comparison shots of the HD2010 copper pill:
As you can see, the amount of copper shaved off is minimized without compromising clearance.
More photos:
There’s a lot of copper above the driver, so if you’re stacking AMC7135 chips, it may not fit.
In the sample HD2010 pill, there’s 3mm of clearance for components above the driver PCB.
If you stack one more layer of chips, I think they’ll touch the pill, but you’ll still be able to press fit them. (Plus, the chips are then heatsinked.)
The HD2010 copper pill can now accept 20mm SinkPad/Noctigons without any problems.
In the final edition, the pill contact surface will be flat, unlike in this sample.
The LED wire path will be diagonal, so that it will connect from the edges of the 17mm driver slot to the 20mm PCB surface.
Here’s some shots of the Convoy C8 pill:
The drivers will be press fit. The retaining rings and their threads have been removed to improve thermal capacity as well as minimize cost.
Here’s how they look assembled:
I’ll post up a pre-order form in a couple of hours.
Pricing will be $20 for the HD2010 pill and $15 for the Convoy C8 pill.
Base shipping will be $3 and add $1 per additional pill to anywhere in the world and add $3 if you want tracking.
The goal is 50 units combined. If we reach 100 units, they will be $18 and $13 respectively.
45 out of 50 units claimed.
There’s not set deadline, but the faster we sign up, the earlier we get our pills.
The machining time is 4 days and the shipping time is 8-14 days.
Cheers!
Hey BLF,
I asked vestureofblood how he would feel about others selling copper pills, and he suggested that I do a feeler thread to gauge interest for different pills.
So I created a quick survey where members can share what hosts they’re interested in.
The results of this will be viewable to everyone, and I hope that this can be used by other machinists to see what members want.
This is not binding of course, just a feeler so that other members and I have a starting point.
Here’s the survey: Copper Pills!
Here’s the summary of the results: http://jo.my/copperpillssummary
Here’s the response sheet: http://jo.my/copperpillsresponses
