cool… another light for resistor mod :heart_eyes: I love this light… it is beautiful light, I don’t care much about the waterproof part, because I don’t plan to stay outside when it’s rain
I mentioned the Vf right below where you quoted me. I see nothing wrong with the way the driver regulates.. There does not seem to be much resistance in it either. :) (tested same used NCR18650B in the L4 and in a light using Qlite and XM-L2. I saw a higher tailcap reading on the L4. Again, probably due to the lower Vf in the emitter)
The change in amps are due to the Vf issues in the emitters, not in the driver. Regulation is good as far as I have seen.
:beer:
btw, no one have actually confirmed that the switch is a weak point for rain...
Ohhh - thanx Jonny!! Was wondering bout that, if Tidos' original had support for it. Didn't seem documented in the code clearly, not sure. I looked at it...
I’ve got .12R, .22R, and .5R resistors on the way… Any idea on a possible combination to score in the 4-5A range? I’m currently seeing about 2.7 on unprotected panny NCR18650B 3400mAh.
Im not even sure unprotected NCR18650B will give you peak output above 4A, either way, it will not stay above 3,5A for long anyway. There is no point in trying to set the light up for really high amps unless you are using a battery that is capable of staying there for some time. Then you will just make the mode spacing worse.
As with all resistors mods, the higher you push, the higher chance of breaking something.
Id say try one 0.12R and 0.22R if you want to get high with that battery. I have not done the math, but it should probably get you close/ or maybe around 4A in theory, if you dont have issues with resistance. Which you might already have..
Nice Tom E, how high will you aim? I expect you to push the limits.. 0:)
I don't have my L4 anymore.. But I might buy another one. Its such a nice light and host. I miss it.
(I actually have 2 different C8 lights on the way, there goes the not buying any more regular C8 lights)
I hope others share their results before and after resistor mods on these lights. :)
Thanks for the mod and teardown info, R86!
The driver is a buck or (probbaly) boost driver of some kind. This explains the difference in tailcap and emitter currents. I’m not sure if it can be pushed to 4A+ without burning up.
I’m liking the look of this light, it has everything in one package (forward-clicky, side-switch for modes, looks good, nice thermal design, moddable).
These are quite good #'s for a stock, regulated light. In fact this appears very well regulated - in the first few secs, the meter dropped steady, then settled by 10 secs or so, and only lost 4 lumens between 10 and 30 secs. Not sure if seen a relatively high amp light do this before...
Not too crazy bout this type of UI though. Not being able to turn it ON and OFF on the side switch is a PIA, though I do like tactical buttons, just want full control from the side switch.
crap - was hoping my SS bezel from a UF light would fit, appeared to be the same size but the thread count per inch is different, so won't really screw on. I have a SS bezel XR-E C8 from FastTech ($13 one) on the way, so maybe that one will fit. Even paying $13 for the SS bezel alone is worth it, but it's still a pretty decent C8 host. I mod'ed up 2 for gifts and they came out real nice.
You know, this L4 is really quality through-out. Ok, it's a crappy copper star, but gotta be better than the average aluminum. The screws holding it down, the heavier gauge wires, of course the uni-body construction as mentioned -- all very good stuff. On mine though, the emiterr centering piece has to get filed down - looks too high. I'm thinking for now, just to do something simple like a resistor mod, maybe AR lens, and that's it, until I can come up with a better driver/UI solution.
