Yes - I'm very impressed with this light. That battery tube is the thickest I believe I've seen for a single 18650.
Ok, rather simple mod, but... Added an R100, thinking little more boost, not too much. Also replaced the wires to 22 gauge, though originals looked like 22 gauge, temp rating of 200C which is rare to see stock, usually it's 150C. New readings:
On same Pana PD, 3.67A tail, Lumens: 1,136 @start, 1,091 @30 secs, throw: 45 kcd
Not overly impressed, thought I'd get more amps than that. 132 lumens bump, about a 14% increase. Sometimes gotta let things settle. I added touchs of DeoxIT, so may need time. Few more minor things to do:
- copper braid springs (may not bump up output, but should reduce the drain of the cells)
- file down LED alignment piece
- drop in an AR lens
Just re-tested on a Samsung 20R at 4.15v, measured 3.57A tail (yes, lower):
Lumens: 1,136 @start, 1,108 @30 secs
Slightly better, but still about the same. Interesting the amps is lower, but think you will see that on this type of driver - maybe the 20R is putting out higher voltage, so the amps drawn is lowered.
Edit:
- Added an additional R200 resistor
- swapped emitter with a XM-L2 U2 1A on a Noctigon
- filed down LED alignment piece
- swapped in a IOS AR lens
On a Pana PF, 3.42A, Lumens: 1,173 @start, 1,153 @30 secs
On a SAM 20R: 3.37A, Lumens: 1,193 @start, 1,204 @30 secs
Weird - amps went down, I assume from the resistor mod, and on the 20R output actually goes up for the first 45 secs or so.
