4C Maglite mod, for a light, for me to carry at work. Done, with beam shots
Especially interested in the battery holder.
Well, there’s a couple more photos of it in the OP now.
Because of the price of copper, anything made with it now, becomes jewelery!
Subscribed, bookmarked and taking notes.
I've been wondering about something while watching the mods that use high currents, and threads looking for ways to reduce resistance in the switch and replacing the switch with a higher rated one. Couldn't you just bypass the switch and hard wire batt- to the drivers ground? Especially in a mod like this where you're already using a master-slave configuration, couldn't you connect all three emitters to a slave, then strip the 7135's off the master? Then, you would only run enough current through the switch to power the master board, basically just the MCU. Or would the 3 slaves cause too much parasitic drain while the flashlight is off?
Anyway, the idea keeps rattling around in my head. If it won't work tell me so I can evict it and think about something useful. Or women. Or cookies. Something.
Absolutely! It’s to the point where I don’t want to even use it any more. 3/4" pipe isn’t cheap. I ended up at Home Depot and bought a 2’ section for seven something and even the copper slip fittings are getting untouchable.
+1
Just can’t believe it’s not an MTG2 …
I’m probably not the one to answer. Are you saying no switch, or just using a switch in the control circuit, so that it only sees very low amperage? I use many of the DrJones programmed NANJG drivers where a momentary switch is used to fire the driver and yes, it does have parasitic drain. I believe that’s one of the problems with doing that style switch, like an SRK or Rook and others. There’s parasitic drain to contend with. I don’t worry about switches much until I get over 10 amps. The Judco switches work well for up to ten amps. I worry more about springs getting brittle from the current thru them.
Awesome, keep up the good work!
Tofty is building a 10A switch, Matt a 20A
He's wondering if hooking the 7135's up directly to the battery, with the MCU only being powered up through the switch, would cause parasitic drain. I've heard about 7135's leaking current when not even switched on, but the verdict seemed to go back and forth on that.
It's a very simple solution though that never crossed my mind :)
Yes, just using the switch to turn the MCU on/off, and leave the slave boards powered all the time bypassing the switch. The MCU would work exactly as in a single board driver with a mechanical switch. I don't see any downside other than finding room for an additional board, pending info on the slave boards' power use when the flashlight is off.
You also eliminate some resistance in the drive path.
Very cool. I like the battery holder/tray thing too. Will be tricky to make all the connections clean and isolated, but a very cool creation. Plus it’s parallel, so you can just pop in/out single cells if you’re in a pinch. Good luck with the new job post.
Battery holder is done. Photos in the OP. Now it's time for drivers.
Incredible. I would not of thought of what you have just done in a million years.
It should be easy to check to slave boards parasitic drain, if you're interested. Just use jumper cables to connect one to an LED and cell with an ammeter. Cheap DMM leads should suffice at that low, if any, current.
Beautiful battery holder! But how are those white wires run down the backside? Are they glued to the backside of the copper pipe so as not to have slop in them and get caught sliding into the body?
-Garry
Any special technique for soldering the discs into the tube square? It looks very robust with coupler backing up those discs. Very nice! :beer:
Nice OL, very nice. Amazing job for your first mag 3-18650 parallel holder. :open_mouth:
After the photos, I took Epoxy and coated them completely. Also, the pieces of coupling at three places, keep the wires from touching the body.
When I soldered the discs into the tube, I used a vise. I squeezed on the sides of the tube, just enough to hold the disc from slipping. I also did the squeezing a little back from the disc, so I could still heat it with a torch, otherwise the vise would have taken the heat away from the copper. The couplers are really just to keep the wires from touching the body. More for spacers than anything else and they are epoxied on. If I had realized I needed them to begin with, I would have soldered them on when I did the discs.
