9V battery inside, a switch, the ampmeter. Packed in some metal stuff he had. Ive only used it for my last two mods, and on the previous one I did notice the difference. But now when I did the tailcap readings I got slightly better numbers. Then again, my custom DMM wires are not super thick. It should come in extra handy when I get past 10A. J) And with general high current stuff where low resistance matters.
You will notice that the light have lost a ton of output when the battery starts to get close to 3V. And once its that low, you get lots of "extended runtime" due to the low output on high. The more I have tested low voltage limits, the less afraid I am om running my batteries low. Because output goes down a lot in a single cell light (atleast when you expect high to have 1000-1500++ lumen) And with a Qlite, you always have that safety, which always have worked when I have tested it.
Ive got no worries running unprotected cells in a setup like this. With the stock driver, that would be a different story. I just feel much safer having a cut off. Its is a great safety feature if your light for some reason should accidentally be turned on due to getting the switch pressed in. If there is a short circuit inside a light, you just fry a spring. So driver circuits can prevent undervoltage. Springs can prevent insane battery drain/short circuits. And if you use a good charger that will not overcharge, there is not much to worry about. Especially not if you monitor your cells.
When that is said. If not having a cut-off Im using protected cells in most lights. My previous mod features a custom "R86" version of the Drjones lumodrv. Its got low voltage cut off among other changes. (I have not tested yet though, partially because a Drjones drivers have a feature to extent runtime by a lot below 3V. Takes ages to drain a cell :p )
Anyway, just test it yourself and get acquainted with how the output drops.
There are some small voltmeters on ebay and various places that can be nice to bring "out in the field" in order to check battery voltage..
Nice build! I may have been the first to use a P60 pill in a HD2010, not sure, but that's how I used to do them. Now I just rotary tool down the alum pill, also tweak out more inside, then press fit in a brass ring 17mm adapter - it's easier/simpler than the P60 pill to get the same height/depth. I add copper in the pill too, but of course now I got copper pills as well. I've done several variations of P60 pill usages - you can dremel down the P60 as well and actually make a simple brass ring out of it.
The SONY cell delivers the 5.9A? Pretty nice! I prefer the Powerizers now, but guess overseas shipping costs may be crazy.
If I do another HD2010, I might just modify the pill like that. Sounds easier. But then again, everything is a bit harder the first time.. Thanks for sharing.
About the copper pills, I can see why people buy them for their HD2010, its easy plug and play. Could you share some measurements before after results in this thread?
I seem to remember that there were basically zero gain at 4,5A in a HD2010 where you compared aluminium vs copper pill, if I remember correctly. Please share in that thread. Many are interested in getting some numbers on this. And so far the results are vaguely various places.
Ive seen 6,4A at the tail in my lustefire triple (with my regular DMM). Just a peak bragging number though. The cells does not seem to perform below my 20R cells, just way better once used.
I originally bought the cells for 10A or higher use. Based on what I have seen documented, they seem to hold voltage better than any IMR I have seen at those high currents.
But if I place a small order from the states, shipping makes the batteries more expensive than they are. And if I place a bit larger order, then custom fee + taxes kills the deal. The sony cells seems to give just as good output, just less capacity. I would prefer Powereizers for a light like this though. Im on the lookout for good IMRs. More capacity than 2600mAh would be great. Maybe WB can get the keepower IMRs in stock that HKJ just tested. They are good in the 5A range, maybe similar to Powerizers?
Ive been using them for a "long time".
Pushing around 10A through them here. And here. Among some lights I have been using them in.
Where did you buy yours?
Oh it sings! :)
I had room for more 7135s, but 5,9A peak is "adequate". I could have breached the 6A limit for a super short time. :p But its not like I will see 5,5A+ at the emitter for much time anyway..
Taking the cell out of the charger and into the light probably helps achieving these " peak bragging numbers" easier. I cant remember anyone documenting such high numbers. Im much more into regulated lights, like my ZY-T08 that does 6,4A "all day" with great battery capacity. But HD2010 is a more compact and comfortable light to hold. Great form factor and its more idiot proof with a Qlite and single cell.
I got my Sony 26650 here.
I know the capacity is low, but I have so many cells now that I’m just picking up various high drain and IMR cells now to play with.
Ok, Ive bought mine from WB in the past. I just wonder about their order count (because I have ordered 6 in total, and total orders say 6). Maybe its a new feature that has not included all sales from the beginning or something.
Ive seen these cheap in larger batches other places, but not sure if those sources are as good...
I got several MNKE IMR 26650, which is the cell in the KP's I believe, and they are way behind what a SONY or Powerizer can do. Maybe the KP's are using a new generation, dunno, but the HKJ internal resistance # is the key spec, and I don't see it competing.
For the copper/alum pill comparison - that's tough head to head. My alum HD 2010 pill mods always have copper added, 2-3 18 gauge discs or equivalent. Not sure if I can ever get true comparison results - takes a lot of time, and one of the main purposes of going with a copper pill is to save time.
The mentioned and latest KP IMR HKJ tested are not much behind the Sony in terms peak performance, its pretty close to it, and better at the end (5A) Must be something better in this new KP cell than the MNKE IMR 26650 based on how you describe the performance of that cell.
If you want to save time, why bother with copper inserts that heats up in close to no time? Have you measured any performance gain with those since you use the time and money to do it?
For the copper inserts, started doing it pretty much because everyone else of note here does (I stand on the shoulders of giants, like so many others). Yes - could question it. Even the master of copper, OL, has questioned it himself - I followed that thread. I believe it helps and so I keep doing it - done dozens of mods this way, but I'm not 100% in my conviction on it for sure, just like OL. Could be the old "making the sink bigger" so it spills later, but even for that there is an advantage. I do believe in core copper and outer aluminum - I believe that is well proven in the CPU heat sinking world, but where the boundary is, how many joints and transitions there are in the heat flow -- it's all important.
I wish I had more time, more money to do more experimenting and scientific testing methods, but I do have a crazy job, being self-employed and paid by the hour (when I take time off, I don't get paid), and the main money maker for the home (wife works part-time, still got a daughter in college).
I love the idea though of your suggestions and totally agree it should be done...
I’ll smile first as I dont want to give anyone any extra work, but not only the copper verses ally pills but also copper and ally stars on each different pill. This is turning into a full time job. Is there anyone retired out there looking for something to do?
Wow, I missed getting volunteered for something! As usual, late to the party and dressed all wrong.
Things have changed a lot in this last couple of months haven’t they? Now the FET driver is the talk of the town, and even I have jumped on the wagon! With new boards on the way and a bag full of new electronics, my USB Programmer sits idly by waiting to program ATiny13A’s for the big guns.
The Buck modded Convoy C8, with a copper pill like the one in my avatar, is sporting one of these FET drivers and making 6.61A through a Sony C4 or Efest 35A cell. Yep, even new cells out, the Sony C5, the Samsung 25R, the Efest 35A…big hitters and higher capacities just in time for the new drivers.
The C8 set up this way is seeing 1673 lumens at start, 1497 at 30 seconds with an Efest 35A. About time things took a swing up, wouldn’t you say?
For the record, I’ve said it elsewhere but the M8 in my Avatar is now sporting the new FET driver and running 10.83A for a start of over 4000 lumens and 3600+ at 30. With modes. Very cool to have near direct drive and also a 7 lumen moon from an MT-G2.
So what am I supposed to be doing? Testing? You mean like, the new cells on a direct drive XM-L2 on copper, no host? Oh yeah, did that, how about the possibility of 7.18A through the Sony C4? With these other big hitters at 6.8-7A their own selves? So 7A seems to be the limit on the XM-L2. Go get em boys!
The FET drivers are interesting for certain lights. But as long as they whine its a no go in this light format for me..
Real life performance differences between a 7135 around 6A and a FET driver in a single emitter lights is not noticeable. Lots of whining from the light is noticeable and I would consider it a serious downgrade..
I would not consider 18650 batteries in a 26650 light either. 26650 cells hold voltage much better in the real world (after a little bit of use) and have better capacity..
I don’t hear anything from mine, and neither do my wife or 6 year old. Not sure why some report how noisy they are and mine are silent.
And there are 18650 cells that hold voltage better than some 26650’s, depends on the cells of course. The Panasonic PF/PD cells are excellent. They won’t, however, deliver 7A to a single emitter but they will give 7.7A to a triple XM-L2. Always options, compromises and flat out trade-offs.
Most of the time, in my own use, the lights I’ve got running maximum numbers are not the lights I’d worry about how long they can do it. When I’m going to need a light for a longer period of time, I select a different set-up.
I have FET modified drivers in a Convoy C8, a Crelant 7G5, and a Solarforce M8 running 6.61A, 5.90A and 10.83A respectively. Holding them at my ear, almost in contact, there is no whine in any of 5 levels. Also of note, each of these has a Tofty 10A+ switch.
