Wow, this little guy is small. I don’t have mine yet, but the photos make it look larger than I would have thought. Looked up the spec, and compared to my ZL600 MK1. My SC600 MK1 is 107mm long, and if this is correct, I found specs that show the DQG Tiny 26650 is 99mm long, 8mm shorter than the ZL, what !!!
I received mine today and WOW this thing is way smaller then I was thinking. This thing is a keeper for me! In turbo mode I got over 6a draw from a king kong lol
mhemling33,
PERFECT. Wow, Thanks so much. Answers all of my questions about what it can do, now all I need is to receive the light, try it out for a while, and see how long it lasts. What a great photo you took. Nice!
Thanks for the review. I really want to like this light, but I hate the fact it starts on Low every time. Is there no way to program it or make it come on in high instead?
Also, can anyone clarify the turbo mode. The review says it returns to your previous select mode.
So if you are on Low and double click you get turbo and then automatically steps down to low again??? Isn’t this a little counter intuitive going from lowest to highest to lowest?
From the pictures of the driver, this light does not have the LED mounted on the driver board like some of the previous DQG offerings. This suggests that the light could probably be modded with a DrJones driver with your choice of UI.
Yesterday i received my DQG 26650 NW, but i’m disappointed :_( It doesn’t work well! When i active the turbo mode the flashlight makes a flash and turns off! Then it doesn’t work anymore, but i have to turn the battery tube until i find a position in which it turns on again, but if i try to go on turbo it stops working again!!….what i can do?
I have written to Ric to explain my problem!
It’s a pity because i like it very much
What battery are you using and is it protected? To me (I could be wrong here) it sounds like it trips the protection circuit on your battery..?? This little guy sucks A lot of current on turbo.
You’re right BIG-P! This is also the Ric’s reply: ” Protection battery can not draw more than 5A current. Turbo mode of DQG 26650 is over 6A. So please try a unprotected king kong 26650.”
I have only Soshine and 4Seves 26650 batteries, so i have to buy a King Kong Unprotected to verify that….i hope this is the only problem
I thank Ric for his support and availability, he is a very good seller!
