To be honest all these 7135/ATtiny drivers are electrically identical. Making a 15mm driver would take no time at all. I'll see what I can whip up tonight after footy training.
As for the firmware - this driver can be used as a normal NANJG driver (no e-switch) provided you have the right firmware. If you want to use an e-switch you will probably need DrJones MiniMo firmware. If you use that firmware you CANNOT solder the bridged marked as number 4.
I just realised I forgot to check with DrJones if he was working on an SRK driver. I know he was working on a larger 4 LED driver that allowed control over each emitter (or cycle through them). If this driver is stepping on his toes (because it sort of relies on his firmware which I did NOT think about) I will pull it from OSHPark.
There are other firmwares out there too (or soon to be - I believe Werner said he was planning to release source code once he has it ready). DrJ also sells bare pre-flashed tiny13s, I think, for his more complex versions.
He put his 7135's too close to the edge, will use ATtiny84 and have a few other high end features. The cheapies will complain his price is too high, but they probably won't buy your driver either. I'd probably build a light with all three. It may be more expensive than I'm willing to try, but I wonder how well your driver with the zener mod using 18350's in 2S4P driving a trio of MT-G2's would work.
Be VERY careful putting holes/leads in that center area of the board. The cells in an SRK are held very loosely and their position can be all over the place. With flat/low top cells it is easy for them to touch things in that center area… kerblewie! Same goes for the outer ring… it needs to be fairly narrow to make sure a cell cannot touch it. Some cells have awfully wide positive contacts…
Also, be very careful depending upon the board solder mask to keep the tab under the AMC7135 chips from shorting to etches underneath the chip. Solder mask should NEVER be used to provide insulation in critical places. Plus, being able to get solder to that tab under the chip provides a much better thermal path.
Finally, I would not recommend paralleling all the AMC chips and the LEDs. At these currents imbalances in the LEDs can lead to run-away current hogging and emitter toastification. My driver breaks up the AMC chips into three groups, one for each LED, 3 amps max to each LED. Yes, you could parallel the banks (like Old Lumens did for hist MTG mod), but I would not recommend it fot things like XML’s.
These issues led to the funky layout of my driver board with 24 AMC chips in three banks.
Thanks texaspyro. I made specific mention of the board being untested for these reasons. The BATT+ contact ring is larger than on the stock SRK driver board so battery wobble should be less of an issue. Nontheless the through hole vias were simply to make soldering wires easier and to reduce the risk of ripping solder pads off. I would obviously encourage people to keep the wires as low as possible.
Points noted on the routing under AMCs etc. I know this is frowned upon, but the point of this board was more to do with big power than anything else. I have identified a way I could potentially improve the design a little bit, but I will wait a while to see if the demand really requires it.
The Qlite has routing under the chips, in the dozens (100?) that I’ve used, it’s never been an issue and so far I’ve run em up to 4 high and over 6A. Lucky maybe, don’t know.
Every cheap 7135 board I’ve seen has the output trace crossing under the chips. It doesn’t mean it’s good design but does seem to work. Breaking up the output into groups could be done just by cutting the output trace in a few places and soldering an led- wire to one of the chips in each isolated group. For a high voltage Zener mod it would be better maybe to have the entire bottom of the chip available for ground trace soldering but maybe not as important for normal 4.2V usage. The natives have been getting restless waiting for an SRK board and this is a sort of stop gap measure. I like that Mattaus is willing to put things out there knowing that his first effort can be improved on and that Texaspyro takes the time to make suggestions. We all learn from them and gain by their efforts.
Very much looking forward to that. Ordered some and I'm off to your thread to figure out how to wire them into this board.
On TexasPyro's point above about contact pads for cells and the battery tube. If there is a problem with this design, I imagine one could reflow some copper sheet cut to the appropriate size over the positive contact ring.
I guess part of the accidental 'charm' of this (or any 7135 based driver) is the relative ease of which the boards can be 'hacked' up. Seriously - I've seen some of the boards people have created, even some I've made, and they look like they've been put through a meat grinder. And yet they still function. Boards with chips stacked 4 or 5 high (sometimes more). Traces ripped up with jumper wires running left and right. Extra components tacked on. AMC chips being driven above and beyond their factory rating. Master/slave setups. The list goes on.
All this board will really ever be is a NANJG driver sized to natively fit a very popular light. If you're concerned about a large group of AMC chips running LEDs parallel then just go to town on the board. Leave a few chips off and stack them else where if you need room. Swap out the MCU for another. Zener mod it. Hell; you could just use it as a simple contact board for an all together completely different driver for all it matters lol.
Use it how you see fit and do what people around here do best - make up for its shortcomings by ghetto engineering the crap out of it.
The problem is not with the contact ring, it is with those pads/holes for wires at the center of the board. The positive contact for the cells can touch them… even if there are no wires protruding. The center part of the driver board really needs to be empty. If I remember correctly, anything within around 0.2” of the board’s center is a risk for shorting with some cells.
It's worth a shot if you already have some, but it wasn't tough enough to work with my reflector and probably wouldn't here either. Fujik should work though.
