($7 delivery price)Cree T6 1000-Lume Led headlamp from Myled.com
Absolutely
I am sure someone that get’s theirs first will do an in depth review for sure…if not…I will do one
Limited to 20 pcs only??? Really?
I saw many people said they bought, I think the deal is not limited.
I ordered one and the PayPal said the correct $ 7.00 total price with shipping. Hopefully i will receive it.
after that many people have many requests so that i was open to more people
it said 8.4V ``
yes you will and you can get the parcel for sure .
I'm 99% sure it's 4.2V.
Would you please take a photo of the battery holder (rubber lid opened)?
I'm afraid so. That's why I'm keep asking. And you know, cutomers would be misled, me included.
So myled would you please clearify this?
I just confirm with my staff , it was 4.2 V not 8.4V ```it was a clerical error 。 Sorry for this trouble
thanks very much for helping to refer this issue
I would say is copy/paste error and not the only one. I'm 100% shure there are lot more. Just take a look your headlights desctriptions. SKU:2420920009, SKU:2420920001 are just some to name.
Didn't have to wait so patiently.. First two of them arrived today!! Ordered July 9th, received July 17th, not bad at all! :)
Initial impressions: Plain white packaging, light are just like I thought (and said) them to be: parallel, 4.2V, 3 modes, PWM on low, smooth reflector. More info in the what you got today thread.
Received in 9 days!
Very pleased!
Received mine yesterday.
Longer protected cells (I tried the Panasonic 3400mAh from Fasttech, the only ones I have laying around not being used in a flashlight) don’t fit. This evening I’ll try to see if this can be fixed by removing some plastic from the battery case.
Next to that I’ll probably mod mine with a defuser of some kind, because I think the beam will be to focused for a headlamp.
Good for you =the=
As always, shipment to South Asia has always been super slooooow. Still waiting patiently….
Here's what I did with DC Fix diffusion film. Much better now. :)
Thanks! Did you use a special kind of film?
Took mine apart yesterday, here are my findings:
- Thin wires used in the battery case
- Soldering from the wires to the battery connections is subpar, looks like any of the soldering could break with very little force
- The star of the led is pushed against the metal by the reflector which is forced in place by screwing the bezel in place. No thermal paste is used.
- Batteries are placed in serial, the headlamp works with one cell
  • Long protected cells don’t fit. By removing a bit of the plastic on the positive side of the case I was able to fit the long protected Panasonic cells from Fasttech. Getting them out wasn’t even a problem.
My main concern is the 18650’s that are placed on the back of your head and just covered with a small piece of rubber. I wouldn’t recommend using cheap cells or cells of different age/capacity/brand. To my opinion it’s an added risk that can be avoided by using quality protected cells. For a headlamp in this price category it’s not feasible to buy quality cells for this lamp only, they’re just to expensive compared to the price of the headlamp itself.
Considering the price I’m happy, but don’t expect a high quality light.
The one I used is not a real DC Fix film, but a cheap imitation from Lidl. :)
Quite similar to this one from eBay.
[quote=CrashOne] Batteries are placed in serial, the headlamp works with one cell [/quote]
You mean parallel, which is good (safer).
[quote=CrashOne] My main concern is the 18650's that are placed on the back of your head and just covered with a small piece of rubber. I wouldn't recommend using cheap cells or cells of different age/capacity/brand. To my opinion it's an added risk that can be avoided by using quality protected cells. [/quote]
That's where serial vs. parallel comes into play: In parallel setup the potential problem appears when inserting cells (= when you can see/notice it), not during usage (= against back of your head). In theory you could use different cells in parallel setup, as long as the voltage is same when inserting those to light. I say "in theory", because I always advice against that kind of usage: Never mix different age/capacity/brand/voltage level cells in any multi-cell setup. (because that's easier for users - no need to know if the lamp is in series or parallel)
Of course, if you are in doubt (and the lamp is with parallel setup), you can use a single cell. :)
Also: Using good quality protected cells is always highly recommended, no matter how cheap the lamp is.
This guy sells legit DC Fix film sheets: http://www.cpfmarketplace.com/mp/showthread.php?246875-Phaserburn-s-Diffusion-Film-DC-Fix-CPF-Service
I haven’t received this light yet, but I’m already regretting purchasing it…
Ah, my bad! Meant parallel of course :slight_smile:
