1+ for a good pocket clip!
Me too.
Would the s2 reflector fit into the s2+ head in any way? I guess driver cavity in the pill is too deep, taking up room. Could be cut down.
Me too.
Could 7135*5 be done?
Or 7135*8. You know you want it!
yes ,but the first batch S2+ can not
ok ,note
i can make it ,but i think big current will damage the battery
Sorry, which question are you answering here?
please include pocket clip
nice one ,will you sell hosts ?
the #5
Smarter Shopping, Better Living! Aliexpress.com
here is the link of clip
yes ,will
7135*8 will not damage a high quality imr18350 or imr16340.
What is the prurpose of the CR123 version, since the body is not thiner ?
If you can make a host with a short body that takes an 18350 I'm in. Since I started vaping I've collected some good IMR 18350 cells that could drive a nice triple LED hot rod shorty. 16340's just don't cut it any longer.
It probably incorporates a boost driver instead of the 7135 linear driver due to the lower voltage of the CR123.
~~X3~~:What is the prurpose of the CR123 version, since the body is not thiner ?
Yeah I imagine so, but if I chose a CR123/16340 battery format it’s not for the capacity…but for the smaller diameter
Simon, could you tell us what driver do you use in CR123 version, please?
More than likely using a buck driver (same ones that use the 1AA/2AA, which means people that can get CR123’s on the cheap have ready made battery supply on hand
Oh and thanks for the AWESOME customer service Simon!
7135*3 single mode driver
