Lol
I like the Fasttech new arrival Sanrenmu GJ017D pry-bar/wrench/ruler for $4.09 indirectly linked by isti242 above.
> I wonder how effective it is as a glass breaker.
Not something you want to test while hanging upside down in the seat belt between rising water and flames.
I recall reading that most cheap “glass breaker” tips are metal, which simply isn’t hard enough — they need some super hard ceramic tip to reliably break glass when there’s no time to mess around.
In this video there is a test of one tool with steel tip and it’s useless:
Wonder if they even bothered hardening the tip. I have a red hammer with hardened tip, like the ones installed on buses. I know they don’t always work on first strike though.
Excellent video showing how worthless steel tips are. You’d be dead.
Interesting video. I would like to try this myself…
on the other hand you never need to break a class from the inside, you can just use the built in window opener…
Eh? Well, probably, most of the time.
Do we feel lucky?
https://www.google.com/search?q=window+accident+open+electric
I was going to try out these “signal lamps” from cnq, but they said they did not have any left. Does anyone know a good place to get them or something similar?
http://www.cnqualitygoods.com/goods.php?id=2032
http://www.cnqualitygoods.com/goods.php?id=2033
I still see no problem but I usualy use German cars ;)… And of course I don’t drive in the water…
Do you guys also have a life jacket in your car…
Many are flood pictures, when you choose the image search
https://www.google.com/search?q=car+crash+rescue+window+break
Search turns up mention of plans that, I think, never went anywhere:
http://answers.google.com/answers/threadview/id/718813.html
+1
The more a tool try to do multiple things the more it become bad at everything…
Just received this knife and can’t figure out how to get the blade out? Not sure if the item I received is damaged or I’m missing something obvious, but any assistance would be greatly appreciated.
On Edit: I’m referring to the Paper Knives EDC.
Which knife?
There are two photos that I can see one above and this one
Notice the position of the slide on top of the knife, they are in the same position but on one the blade is retracted and on the other it is open. Could it be that the blade needs re-positioning after shipping. A lot of these blades have two cut-outs on the top of the blade allowing different positioning.
Sorry I don’t have one so I can’t tell exactly what the problem is.
Pictures would be good.
Just pull it out, helps if you push outwards the retaining spring on top at the same time. I was a bit puzzled at first with it too.
I made a GIF showing how to extend and retract the blade:
There’s a frame lock along the top, where my thumb is. Press the frame open and you can slide the blade out. Release the frame to lock it in place. (this may take some jiggling) Repeat to retract the blade back into the frame.
If you look at the photo above that isti posted and the photos I linked too on the AliExpress page then the blade is retracted and extended with the slide in the same position?
