Eh? Well, probably, most of the time.
Do we feel lucky?
https://www.google.com/search?q=window+accident+open+electric
I was going to try out these “signal lamps” from cnq, but they said they did not have any left. Does anyone know a good place to get them or something similar?
http://www.cnqualitygoods.com/goods.php?id=2032
http://www.cnqualitygoods.com/goods.php?id=2033
I still see no problem but I usualy use German cars ;)… And of course I don’t drive in the water…
Do you guys also have a life jacket in your car…
Many are flood pictures, when you choose the image search
https://www.google.com/search?q=car+crash+rescue+window+break
Search turns up mention of plans that, I think, never went anywhere:
http://answers.google.com/answers/threadview/id/718813.html
+1
The more a tool try to do multiple things the more it become bad at everything…
Just received this knife and can’t figure out how to get the blade out? Not sure if the item I received is damaged or I’m missing something obvious, but any assistance would be greatly appreciated.
On Edit: I’m referring to the Paper Knives EDC.
Which knife?
There are two photos that I can see one above and this one
Notice the position of the slide on top of the knife, they are in the same position but on one the blade is retracted and on the other it is open. Could it be that the blade needs re-positioning after shipping. A lot of these blades have two cut-outs on the top of the blade allowing different positioning.
Sorry I don’t have one so I can’t tell exactly what the problem is.
Pictures would be good.
Just pull it out, helps if you push outwards the retaining spring on top at the same time. I was a bit puzzled at first with it too.
I made a GIF showing how to extend and retract the blade:
There’s a frame lock along the top, where my thumb is. Press the frame open and you can slide the blade out. Release the frame to lock it in place. (this may take some jiggling) Repeat to retract the blade back into the frame.
If you look at the photo above that isti posted and the photos I linked too on the AliExpress page then the blade is retracted and extended with the slide in the same position?
Thank you and to everyone else who responded.
For some reason, I though there would be a small release button like on standard utility knives. I’m quite disappointed with this knife as I was expecting a little better quality. Much thinner and flimsier than expected. Both slabs of metal has significant pitting and even the blade that came with it was chipped. Oh well, $7 lesson learned.
Has anyone heard from Chloe lately?
Why didn’t you buy the Rexford version for $150 ?
Nope, she’s not been around for a little while, not posted on britishblades forum where she was active too.
Since FT, er, neglected, to publish my 2 (of 5) star review of this mini biner: EDCGEAR “S” Shaped Stainless Steel Anti-theft S-biner Carabiner, https://www.fasttech.com/p/1890000
Save your money!
This has to be the worst clone of the nite ize biner — https://www.fasttech.com/p/1792300 — ever. The security lock couldn’t initially be operated with finger strength. After I took a pair of pliers to it and wrenched it back and forth a while, it bent the gates enough that it could actually be used, though barely.
Thanks Essexman. I hope she is ok.
