I was told that also many times, so I started measuring at longer distances (standard at 5m now), but for an aspheric light that did not give significant different numbers from measuring at 1 meter.
i am facing a problem with the driver i have modded it with a resistor equal to R010 and i was getting 2.6 at the tail cap reading with a XP-G2
and suddenly the flashlight stopped working and then i found a component on the driver fryed, pics will tell, it is the component that the ( - ) to led wire is connected to it and there is another one beside it with the same name but it looks nothing happened to it
the one on the is the damaged one
so any solution ? what is this component ? and can i replace it ? if no any other driver ?
well as i cant fix this driver and i know i cant find a 17mm driver that can take 2 cells in series so i will trim the bill and flat it then i will try to use a 26mm driver something like this TR-0124B 8.4V but i want a driver with a smaller height so can any one please suggest me a driver with 26mm diameter with a short height and can be modded to 5 or 6A ?
I am using this 17mm LD-40 (or LD-4B as how IOS calls it) in my 1405. This driver delivers about 2.2~2.3A to the LED in stock form. I have replaced the the R100 resistor with two stacked R120 resistors and measured 2.45A at tail - which should be translated into >4.0A to the LED.
It works, but I must say the driver is really pushed to its limit already. The mode changing has became problematic after the resistor-mod, and the light cannot be left on high for more than 4 minutes, otherwise the light will becomes dimmer and dimmer over the time and finally shut off by itself. I thought either the driver or LED was burnt but after a few minutes the light works as normal again. I think the driver cannot handle the heat produced at boosted current like this.
I hope you will finally figure out a way to use a larger buck driver in there, because this is also exactly what I wish to have with my 1405.
I have a similar problem, the modified 1405 I just bought from someone on this forum started smoking as soon as I turned it on and burned up the driver. It was almost a really bad situation as it burned the battery holder and almost burned the battery before I could get them out. I am now gonna rebuild it with a new driver and looking at the LD-4B linked above because it can be used with 2 batteries. I dont really want to cut/ or use a dummy cell as I need the run time of two batteries for my work. However, looking at the LD-4B driver you linked, I noticed it says,” *Suitable for 1-2-3 18650, 16340 or 18350”. Does that mean no 26650? And also since the input voltage is for,” *Input voltage: 3-16V ” could I add an extension and add another battery?
Your 1405 situation sounds like a short-circuit to me - a short-circuit which involves two batteries in series, definitely not fun at all. My advice to you is make sure your batteries are still healthy before you use them again, check if they still can be charged without overheating, and see if the batteries still can hold the charge for more then 24 hours without significant drop of resting voltage.
I stacked one R100 resistor on the stock driver and it has killed two of my emitters in a split second due to excessive output voltage - something is not right after the resistor was added. Now I label the stock driver as scrapped part so that I won’t forget and reuse it again. Everyone should be reminded that the stock driver of 1405 is not good for high current application. ohaya and wight have done some test and analysis this thread and it is found not suitable for current boosting. I know some members may have good result with the stock driver anyway but I think there is still certain risk associated with it. And I don’t think LD-4B is good for current boosting either.
To put it simple, we don’t have a reliable and high-current capable 17mm buck driver yet.
26650 has the same voltage as the 18650 (neglect the different chemistry), so yeah you can use two 26650’s with the LD-4B driver without any issue, given that your LD-4B is functioning properly of course. By adding another extension does that mean you will use three batteries? So the input voltage will be 12.6V? If that is the case I believe this is still falling within the specification of the LD-4B thus acceptable, but I have not tried and confirmed this yet so just take my words as a grain of salt.
Messing with lithium batteries especially in series could be a dangerous thing, please be careful with everything you do.
lawenforcementguy, are the batteries protected or unprotected? If the one showing 0.0V is protected battery then maybe it is just the protection circuit failed, or need to be reset; But if it is unprotected battery then I’m afraid 0.0V means the battery is gone.
Chazzy, wow you have boosted it to 3.6A! that’s too high for this driver and I guess this is exactly what causes this to happen? My stock driver already failed at 2.20A measured at tail (only one extra R100 was addded).
Yeah they were unprotected, but for sure the next ones will be protected! Taught me a lesson for sure. Chazzy, no worries I knew it was a gamble anytime to buy modified stuff I sure ain’t blaming you. I am looking forward to doing the new driver myself and learning more.
Since you want to keep it running with two batteries I think LD-4B is the only choice at the moment. If you don’t stack resistor on the LD-4B the output current is about 2.2-2.4A to the LED (particularly from IOS). If you use dedomed XP-G2 you will still see fairly good throw running it at 2.4A, probably around 250kcd and you have the good High-Med-Lo modes.
And again stacking resistors on the LD-4B is not advisable. We just got to be a bit conservative with this driver for better reliability especially you will use it on your duty.
