When I hear name Djozz it immediate associate me to BLF. Djozz is BLF.
To continue testing... Forgot to say that right lenses can be put at shorter distance from emitter for best focus while left lenses need spacer and of course larger distance from emitter, and Goread a2 lenses needs 2 spacers and greater distance from emitter to achieve best focus.
Thank you both luminarium iaculator and djozz for helping out here.
When I was talking about identical diameter of lenses will produce the exact same candela (throw) I was assuming everything else is same (including the lens quality) except the focal length - Sorry for not making it clear earlier.
So now, with the improved switch and shorty version, this flashlight brings 400kcd in reach of even the clumpsiest/laziest budget flashlight modder!!! :-) :-)
So, yes, now the 1405 is a very very worthy zoomie!!
I have asked the sales rep in Alibaba and they told me they have not started mass producing this shorty version yet. They need to wait until some retailers (like FT, BG, GB…) make orders then only they will start producing this shorty version.
Yes I forgot to mention that this shorty version is named as “1504” as shown in their website as well as on the head itself haha.
Yes the 1504 is the best bang for the buck thrower at the moment! But there is one annoying thing about the 1405 (and probably same with this 1504), that the focusing for maximum throw is out of position, did anyone else realize this? The lens was sitting too close with the LED, and I had to add a piece of wire under then o-ring to “raise” the position of the lens and now it is perfectly focused.
Lux reading of my modded 1405 before and after “raising” the lens:
Before: 310kcd
After 365kcd
That makes quite a lot of difference. I do believe this problem still does exist on the shorty version (1504).
Ask them to do a version with XM-L2 U2, a decent driver (at-least 3A on high) and without the cr*p battery. This version is only with IR LED.
Maybe we can get a group buy.
I will try to suggest them using high current driver or even better with Nanjg 105C driver, but I doubt they will listen to me.
I have already owned a 1405 too, so unless the price of this 1504 is really good and hard to pass up otherwise I don’t think I will buy the same light (literally) again.
I have contacted with someone from Uniquefire and suggested to make the new Uniquefire 1504 the new shorty one with an Anti reflection coating on the LENS, well they have responded 2 times
First they thought that i was talking about the flat lens that comes with reflector lights,
This is the first message they sent
Hi khaled ahmed,
Have a nice day!
The UF-1504 will be produced next month as you said,
The suggestion you gave mean that the lens will be the flat glass lens with reflector cup, not convex lens, is that right?
Then i explained and sent to them a pic for the JAX Z1 lens with the Anti reflection coating on it wothout sending the name of the light only a pic for the lens
They responded with the following
Hi khaled ahmed,
Ok, I will negotiate with production department about the change,
I hope they really make this light with the AR Lens
Well, this is quite tricky. I did chat with the Uniquefire sales rep in Skype many times before. If you contact the seller with the name “Shenzhen Homesafety” in Alibaba then I think yes, they are good manufacturer who has sales rep that answers inquiries.
But I still believe that there are other Uniquefire “clones” in China…
