Osram Golden Dragon lights?
That's correct. The P31 still has decent spill, but most of the beam is concentrated in the hotspot. The AA-S1's beam is more spread out evenly. I like the tint of the Hugsby way more.
In Don's review of the Hugsby P31, he claims that it's the brightest AA light that he's seen. It's very true.
With the critical proviso - on NiMH. Many AA lights that can use them are a lot brighter on a 14500
Your lightbox number for the AA-S1 on 14500 is a lot higher than the Hugsby. Does it look like that by just looking at the beams with your eyes?
I was on my way to buy a Hugsby P31. If its brighter than my AA S1 i just had to get it. But then
I remembered that its a AA-only (max1.5V) and it just could not be as bright as a 14500 light.
I put a 1.5.V battery in the AA S1 and compared it to my Romisen G2 II Q5. The latter won by a mile.
With a 14500 in the first one, this totally wiped out the light from the Romisen.
The quality of the AA S1 is the amount of floodlight this small light can produce. For throw you better
choose another.
Don: Why is the Hugsby P31 not in your spreadsheet with estimated lumens? Is the P32 a P31 with
modes?
I'm really liking the R5-A3 now after I changed the reflector to OP. It's really really bright and with a beautiful beam.
On the box of my Hugsby P31, it says "0.8-4.2V." However, I don't want to put in a 14500 and ruin a good light.
Has it affected throw?
It certainly would be nice to know if it accepts 14500.
No. As Don have pointed out above, its only if both have a 1.5V battery the Hugsby is brighter
That's not true with mine. Like I said, my Hugsby nimh has more throw than the 14500 AA-S1.
Don's lightbox may be measuring overall light output. Correct me if I'm wrong Don.
I'm sure it did affect the throw on the R5-A3 by a little bit. However, the smooth reflector never threw far either because of its small size.
In one of the reviews from DX, someone tried a 14500 in the Hugsby and said it didn't make a brightness difference, only that it got hot really fast. Based on that review, I'm not going to even attempt it on mine.
[/quote]
[/quote]
I read this "With the critical proviso - on NiMH." and recon he have tested it. I dont have the Hugsby,
but Im sure that the total output from a 14500 are greater than from a 1.5V light. I have some and
have "testet" them all against the AA S1. None are better. Flood and throw are two different things
though. So maybe Hugsby´s 150 lumens are more concentrated in the hotspot than the 280 from the AA S1.
Have you testet both of yours?
The reason for the lack of P31 numbers is that it was bought to give to someone as a replacement for a failed light - it was only in my hands for about 2 days. It is now in regular use by a cop. Our local constabulary only issue alkaline AAs so i looked for something with good performance on those.
AFAIK the P32 is just a P31 with modes and I like it a lot. It certainly seems to be just as well made and is certainly exceptional quality for the price which is less than I paid for the P31 which was $14.31. The P32 was $13.something. Unless you are hooked on single-mode lights I'd definitely say get the P32 instead of the P31.
Yes, the lightbox measures total output, the throw number is got by clamping the light to my desk, the base of which is exactly 1 metre from the ground, so that the emitter is level with the base of the desk. Then I move a lightmeter around in the hotspot till I get the highest value which is sometimes not in the bit of the hotspot that seemed brightest to me. In other words, the throw value is the absolute highest value I can get out of the light. This tends to favour lights with small hotspots - a light can have quite low lumen output but still throw farther if just about all the light is put into a very narrow beam - think the useless light you get in Doom 3.
It would be more accurate to measure the value at 5 metres and calculate it back to one metre using the inverse square law but I have no light-tight part of the house that has a clear path of 5 metres. Maybe the basement after dark but it is cold, damp and doesn't have enough height to stand up in. Also the hatch hole is very small and I have to empty out a cupboard to get in there in the first place.
[/quote]
[/quote]
Thanks Don
KD has the P32. Kost 13.57$ They state its a 90 lumens light. DX says 160 lumens. Both are Q3.
They are probably unreliable both of them. I trust your measurement. midieval10 says that box says
4.2V max. I may buy one to try it with a 14500.
The AA-S1 with a 14500 is clearly brighter than the P32 with NiMH - the hotspot is several times the size though the spill is of similar brightness - the beam from the AA-S1 is wider. Here's a beamshot about 60cm from the ceiling. Will try outdoors beamshots of the two once it gets dark.
Thanks again Don. I could not understand why the 1.5V Hugsby could be brighter than the 14500 AA S1.
Your picture clearly show that its not the case. The hotspot also is not as bright either.
Maybe midieval10 have received a special (new?) version since his is brighter. If wee kindly ask he maybe
would send a beamshot picture of his two lights together?
Here are my beamshots. They are taken about 70cm from the ceiling. All batteries are charged to fullest prior to shots.
Left to right:
Trustfire F23 10440, Hugsby P31 nimh, UniqueFire AA-S1 14500
Trustfire F23 10440, Hugsby P31 nimh, Uniquefire AA-S1 14500, Trustfire R5-A3 14500
Hugsby P31 nimh, Uniquefire AA-S1 14500, Trustfire R5-A3 14500, Solarforce L2 with XPG-R5 18650
Hugsby P31 nimh, MXDL SA-28 18650 full flood, Solarforce L2 with XPG-R5 18650
Wow! Quite a difference between yours and mine. Mine was bought when they were first launched - early November 2009
Yes a huge difference. Your AA-S1 looks so bright!
You are talking about the AA-S1? so yours is brighter?
This is quite a difference and I think its clear that his AA S1 is not as bright as
the "original" ones. Have they change led or driver I wonder?
