-A very useful size for a couple of AAA-flashlights (Ultrafire M5, Ultrafire LZZ-06 and clones) is 11mm as well, can you make that one too?
-I do not have the knowledge to sort that out, can anyone find out an ebay-link to a LFPAK33 FET for this driver? I can not judge if one is suitable, and all I seem to find are ones that are over 3 dollars each.
djozz, are you sure about the Ultrafire LZZ-06 driver being 11mm, my Jexree Mini that i thought was as far as the body & head goes (they have only different reflectors) would be the exact same light is a 11,6mm driver.
I looked up this FET on Ebay and found no sellers that sell them for less than 3 dollars a piece plus $4.50 shipping :-(
To search Ebay succesfully I -unfortunately- was forced to look into all those different FET-packages :tired: . In the end I found this graphic somewhere in a NXP pdf. Perhaps this saves some other folks a bit of what I have gone through:
I would have to take another look at it when I'm home.
Ok, found it. I looked into an old thread of mine: https://budgetlightforum.com/t/-/25476 and the driver of the LZZ-06 is even 13mm (press-fit), I got it all wrong, I remembered that the driver that I used was a mm too narrow, but it was a 12mm board that I used, not 10. Sorry Richard for doing the work, I promise that will keep looking out for a 11mm driver flashlight to build this 11m board in .
djozz, I spoke with Mouser today and was told they have offices in Munich and the UK, so you should be able to order the FET from Mouser there in Europe and not acquire the big shipping charges. As I recall, this should be just under a dollar apiece. Providing EU Mouser has them, of course. Digikey should be similar.
OK, so 13mm instead of 11mm? If we're going all the way up to 13mm, then I might space things out a little bit more so it's a little easier to assemble.
If you are expanding it to 13mm, do you think it would be possible to fit the 7135 on there also?
I have been studying wights 15mm driver single sided FET+7135 that is sandable to 14mm, he used the SSU of course, and if you use the LFPAK33+0603 smd components+ the attiny13a-mmu i hope it could fit
The light i would like to use it in, is of course the Jexree Mini, for that it would have to be sandable to 12mm, and it would fit djozz Ultrafire LZZ-06 also.
Sorry djozz, i was wrong about the 11,6mm driver in the Jexree Mini, i must have mis calibrated my caliper, it is a 12mm driver.
One very nice thing about this MTN-12DD is that if & when RMM starts to sell these single sided 12mm fet drivers, those plus an XP-L on an 10mm sinkpad is a total drop in for the very nice 10440 host the 5$ Jexree Mini :bigsmile: Can you say ~1000 lumens at start from some very affordable parts
Richard you really should considering selling that combo as a quick and relatively easy modded light in your store, there are not many 10440 hosts that can take a DD driven XP-L but this one can, and i bet you can sell a bundle of them and with a sane shortish turbo timer they should be quite safe even.
I think that what would be more feasible on a 12mm would be pads where you could air wire a 7135 if desired instead of having it mount on the actual board. There isn't room for it on the board.
