Mine doesn't look like it is 10,000K, more like 7,500K or so. It looks slightly cooler than most of the 1As.
I also tried pushing one past 3A and the results were underwhelming. I don't think that this LED deserved a new name, as it pretty much performs like a slightly higher binned XP-E2 and can't really handle more current.
I made a topic of the light loss in this zoomie: http://www.budgetlightforum.com/node/38424
Yes, I personally have never dug into 'kcd' but it is the same number so I never bothered . I always use klux@1meter because that is how I measure it: I measure the klux@5meter and calculate back what it is at 1meter (times 25). klux@1meter is a sort of standard way to represent throw.
I will be good, and use kcd from now on. But I still think that using klux@1m, although not the proper unit, is more clear for the reader because it gives a direct clou of how it is measured.
I’m on a mission, just built my 7th Eagle Eye X6 light, another Quad. The “weakest” in my line-up, this one has 4 of these XP-E2 Torch emitters under a Khatod optic that claims 10º. With a 17DD Hybrid S driver and TK’s A6 firmware it’s pulling 8.24A from a Samsung 26F for 1749.15 Lumens.
It’s got a pretty nice hot spot for a quad, but it doesn’t look like what you’d expect from 20º (I think the 10º figure is a half-angle, always deceptive that)
About to try a hotter cell and see what’s shaking with these tiny emitters. I’m assuming they can handle it….
Edit: Oops! Make this my 8th, forgot about building the single XM-L2 U3 1A that does 1811 lumens. Planning 10 X6 lights that are all different. I have 3 Quads, but each is a different set-up with much different results.
Edit II: OOOPS! Seems like the little XP-E2 Torch and myself are not made for each other. North of 12A one died. A second was injured and limping (dome separation).
So I did what I had to do, I put 4 XP-L V5 1A de-domed under the neat looking Khatod optics.
Stick 6A-8A worth of 7135s in there and call it a day! I know that the little XP-E2 torches can handle 3A, but after 2A or so you're not gaining very much.
These would be ideal with a driver like the PZL, use the 7135 chips and control output values within that 2.5A-3A range per emitter.
The Quad was working nicely at 8A, the Samsung Lavender 26F that I recently got 8 of (protected, too long, stripped the protection and now they’re useful cells) ran it just fine. But I just HAD to stick the HE-2 in there…
Well, I didn’t fry em outright, just melted the dome loose off 3 with one being killed when the dome moved. The other 2 died when removing the domes. That’s 8 that I’ve killed.
