+1 on the glow in the dark as an option, can you make a height adjustable centering ring? Or sell ultra thin shims for the final focusing tweak?
Hoop. If I Promise to only get in your way six times a day can l please come around and watch.
Isnt that Fasttech transperant XML to XP converter do the job? Havent played it alot, but i did it once with a XLP emitter….yet, the reflector was OP
Old-Lumens, thanks for all the specs. I have modeled them all and will add them to the order queue in post #1 here soon.
LED insulation gasket built with a 3D printer I still need some.
Can do but need dimensions provided.
How about centering rings for Convoy C8 reflector and XP-G2/XP-E2 leds!
Sure. For the life of me I can’t find my C8’s stock centering ring so I’ll need the specs as far as the od, id, and the thicknesses.
How hard would it be to make them out of GITD material?
No can do. GITD paint is my suggestion. Get it from GlowInc.
Common paper has a thickness of .003” or so. The shims could be stickers or regular paper. I could have sticker company or printing company die cut these for me but they will probably be .50¢ per shim from what I’ve seen, if I get a couple hundred made. Alternatively, if you determine the optimal thickness you need through testing you could then have me make a centering ring to the exact size you need.
GITD paint isn’t a great option, all the ones I’ve tried glow ‘spotty’ rather than as a full ‘block colour’ glow, this is the reason I made the flat type and didn’t use paint, plus the reflector will strip the paint off when it’s screwed down.
I have something in mind for a future project but I don’t know if it will work, time will tell.
Depending on the plastic you may be able to put one of my GITD gaskets underneath the centring ring i.e the clear white type as opposed to the white opaque type, will dim the glow but might work?
Updated OP with pics of current progress. The ring bosses for the MT-G2’s and XHP-70’s, the portion that goes into the reflector opening, is currently modeled at .030” tall. For smaller led’s I will probably do .02”. Feel free to specify the height of that if you wish.
Wow Hoop, thats great. I will certainly keep this in mind when prototyping.
Hoop - on the ring for the 26mm Maxtoch, you could go ahead and make the centering ring portion complete, on all four sides, as there is room on that one. Other than that, they look good to me, but others need to jump in and say what they think.
Ahh yes. Thanks O-L, will fix that.
Also, I’ve measured the MT-G2 at .352” square. .365” seems like a lot of clearance. Should it be smaller?
Ahh yes. Thanks O-L, will fix that. Also, I’ve measured the MT-G2 at .352" square. .365" seems like a lot of clearance. Should it be smaller?
Might just be my incorrect measurements. I got .362" and went with .365", but I can go check again.
Edit: I measured one that was on a star and got .360" one side and .357" the other side. I went and measured one by itself and I got .353" one side and .350" the other side, so the difference has to be solder or flux or expansion from heating and soldering, (possible? probably not).
I would at least go with .360" myself, but you're the machinist and I am not the most knowledgeable on clearances and dimensions. My digital caliper is cheap, and not 100% reliable, but then again, neither am I.
Oh, the three I "gave specs for", are just suggestions, cause I haven't seen any other specs come out. I can't say they are the best or the right ones, just ideas that might work.
For sure, I appreciate it. I modeled the squares at .360”. I might have to add little notches to all of the LED squares to allow for the excess solder blobs… Or the end user could use a straight razor to cut off the excess solder. That works well in my experience.
Very cool to offer these things, exactly what I need right now.
I’ll work out the dimensions and get back to you!
Any chance you could do black nylon instead of white?
Would everyone prefer black? It would be easiest to offer one color because I will cut these at the same time from a single sheet. I can do black though. Things made from thin sheeting like O-L’s .015” washers may not have a color choice, but I will look into it.
Hoop.
I don’t want to go off subject, but it looks like you have the know how and means to make a 21mm SinkPad centering tool so we can make our own 16mm XHP70 and 16mm XML Color SinkPads. Stick the 21mm SinkPad in the plastic centering tool and punch it out with a 5/8” (16mm) punch. Kinda like you see in this video. Is something like this doable? If yes then all we got to do is buy a centering tool from you and pay a visit to Harbor Freight.
My hunch is that simply punching the stars may not create a sharp enough edge to prevent shorts, but it may be ok with a little bit of cleanup. I think you could punch them close to 16mm but oversize, then use a sander to finish the job. This would save time over only using the sander. The sander method has been successful.
I have however been re-machining XHP-70 boards from 20mm to 16mm, and they do not short. The star gets chamfered on both sides. I can also do this with the LED’s pre-soldered on the star without damaging the LED. These and the colored stars will be available shortly. I really had expected the star manufacturers to offer these by now but since they aren’t, it’s about to time to fill the void.
In regards to relief for the excess solder, I could do it a couple ways. The version pictured on the left is easiest, and I can complete those in a single operation. The partial relief on the right would require a fixture to be built for the secondary operation. For one off’s I’d have to stick with the left side version, but if a particular star becomes more of a standard offering, I could do the other style. Thoughts?
No preference for me regarding the cutouts for solder balls, so whatever is quickest/easiest. Personally I’ll just cut a bevel or cutout if needed with an xacto blade.
So my request would be for the following:
XHP70 led to fit an SSC-P7 C8 reflector. (either white or black is fine for these)
Quantity: x6
Led Cutout: 7mmx7mm (whatever is your standard for XHP70s)
OD: 12.5mm
Reflector Hole Diameter: 9.25mm
Thickness: 2mm base + ~1mm lip
Notes: Non-continuous lip as shown in your examples. No cutouts for solder balls required, no fancy outer shape, circular is fine.
SBT-70 led to fit KD 86mm reflector (would love it if these could be black if possible)
Quantity: x2
Led Cutout: 11mm x 10mm (rectangular but centered)
OD: 26mm
Reflector Hole Diameter: 19.5mm
Thickness: 1mm base + ~2mm lip
Notes: Continuous circular lip. No cutouts for solder balls required, no fancy outer shape, circular is fine.
XML2 led to fit KD 86mm reflector (again black if possible)
Quantity: x2
Led Cutout: 5mmx5mm (XM-L2 standard)
OD: 26mm
Hope that’s enough info, if you need clarification on anything let me know.
Cheers and thanks again for offering this, very cool!
Linus
EDIT: Changed lip to 2mm on 86mm rings
It seems like every time I have to use a butterfly spacer I have to cut more off because the solder pads are under the tabs. A design with the square cut at 45 to the tabs would fill a missing nitch. The 16 mm Sinkpads are my source of angst.
