Did some work on the light today removing some material from the reflector to make it fit into the compact configuration (2x hoods + uv filter lens)
Here’s after the first assembly.
The reflector is a beast, though it doesn’t have the most perfectly smooth mirror finish. A very slight OP surface can be seen here.
I have yet to see how it performs in this config but this feature/flaw may make it a good option for an mt-g2 or similar just to help smooth over the honeycomb artefacts slightly. Just a thought, I’m sure it will also produce a very respectable beam with a normal die.
The UV filter and lens on the front: This is a really cheap UV filter but has what it claims is a multiband AR coating. Multiband? Hmm, probably not. But it definitely knocks down the reflections and the unusual green bias has the added benefit of counteracting the green tint shift seen from a dedomed cree led. So this may not be a bad option at all.
Still waiting on some parts to do a working assembly of the full light (led will be an sbt-70), but so far everything is lining up nicely. I like!
I received 3 Grey Courui’s yesterday, and one will not turn on, the same batteries powered up the other two, so I think the driver is bad, possibly the switch? I’m dealing with GearBest now, let’s see how it will be handled? The lights(all 3) are typically dirty inside and out. The reflectors show pitting but it looks like it was there before the Vap Coating was applied. GearBest order #WW1504201453507112. Out of the 6 I have got recently, really only one was what I would call very good?
I haven’t seen a gray one yet, but I also get the feeling that the quality of the recent batches from Gearbest is on a general downward trend.
The latest black one I received had some generally sharper/rougher machining on the battery tube and worn anodizing on parts of the knurling. The head and reflector also shows signs of being of a lower general quality though no hazing this time.
Anodizing colour is also inconsistent between the last two I ordered, one is a deep black and the more recent one slightly gray.
GearBest has come thru on this by sending another light for $6.00 for shipping, thanks GearBest! Hopefully this one will be clean and working? Thanks Angelia!!!
My last mode with all springs bridged and R200 removed was pushing 4+A to the LED, what if I dont see that power with all these on board. I mean there is a lot more chips that I dont know, what are they purpose?
the led works fine ,i tested by making the driver “direct drive”.
i started replacing parts from the other side of the driver since this new version has double the staff and when i replace those 3 leg in red ,driver works now,i also removed that blue big thing shall i add it back ? whats is its purpose ?
