Oh, now that would be nice 219C
I will see what we can do. I don’t want to add to the cost too much to keep it affordable.
Heheheh….yup! But, it is still fun!
1 x Al NW set. Many thanks!
Interesting suggestions, SL. The team shall discuss. 8)
Yes
As soon as we figure that out.
Yes…pocket clips all around.
Not yet. This light only exists in our minds. Perhaps we can get some design renderings soon.
I don’t know…but it will sure look cool
Not sure. That would certainly add complexity to the GB, but I will see what we can do.
I love cigar grips also. Will look into it!
Problem…what problem :bigsmile:
+1
Krono, how epic would it be if we could get them to do the SS version with the finned head portion in Cu like djozz suggested, this would solve the heat issues and would look exotic as hell!
Effectively something like this… the Solarforce M8 with a copper pill by Bucket…
THAT is PRETTYYYY
Then the SS version and the Cu version would match, with copper for the light engine all the way around… a necessity for the FET driver.
That would be incredible! We will ask!
Perhaps the cost difference could be mostly balanced out by having the smaller K6 also in SS with the Cu finned light engine area. This would use less copper for the smaller light, only where it’s really needed, and then include copper in the larger SS X6.
They’d both then be SS and Cu, matching “His and Hers” lights if you will! Sitting in the case as a gift, they’d be a jaw dropping pair of lights to be sure!
Edit: Optionally, the SS could be dropped and Aluminum used with the copper pill, polishing the alum and using a clear or non dyed Ano. Cheaper body materials, lighter weight, Cu only where it’s needed and still a shiny bling bling look.
one Aluminum (Al) set.
NW , XP-L HI.
Some interesting suggestions on improving this setup! We will discuss them all and see what we can do.
Keep in mind that these lights will be Serial Numbered…so… the sooner you get you name on the list, the lower the S/N you will receive!
krono
updated in OP
