1. If the flashlight is rechargeable or un-rechargeable? Rechargeable 2. What kind of battery does it use? 18650 3. What kind of LED does it use? Cree xp-l 4. What would be the lumen output? 999 lumens 5. What features would this flashlight have, as you know IMALENTflashlights always have innovative feature for each flashlight? Variable output by turning a dial .magnetic switch. Built in charger. Programmable modes.low battery indicator. Strobe,sos.beacon. usb programmable. Remote controlled. 6. If you can do flashlight reviews or you have time to take some good pictures or videos, let us know several of your history reviews or videos, you will have priority to get the chance.
yes, we would be happy to check some of best reviews, if you are unable to post here, can send us by email, I will keep them in document and it will add more points for you to get one.
1. If the flashlight is rechargeable or un-rechargeable?—- Rechargeable
2. What kind of battery does it use?—- lithium-ion
3. What kind of LED does it use?—- LED manufactured by Cree
4. What would be the lumen output?—- 950 lumens
5. What features would this flashlight have, as you know IMALENT flashlights always have innovative feature for each flashlight?—- Rotary-type brightness control
6. If you can do flashlight reviews or you have time to take some good pictures or videos, let us know several of your history reviews or videos, you will have priority to get the chance. —- Can take photos, no flashlight review so far.
3. What kind of LED does it use? CREE XP-L HI
4. What would be the lumen output? 1020
5. What features would this flashlight have, as you know IMALENT flashlights always have innovative feature for each flashlight? flat touch sensitive switch, adjustable brightness via rotary section around switch.
6. If you can do flashlight reviews or you have time to take some good pictures or videos, let us know several of your history reviews or videos, you will have priority to get the chance. None published yet , but plan one in the next month. Can discuss via PM what I would publish if you gave me the chance to review one of your products.
1. rechargeable
2. 18650
3. Cree XML-2
4. 1000 lumens or more, with time based stepdown
5. Stepless brightness adjustment by rotating the tail, capacitive momentary switch at the tail, locator led at the tail, micro usb port for recharging, and hopefully programmable UI
6. Possibility to take some pictures.
Rechargeable
18650
XML-L2
10-1000 lumens!
Touch control?
6. If you can do flashlight reviews or you have time to take some good pictures or videos, let us know several of your history reviews or videos, you will have priority to get the chance. Bike headlight review on MTBR.
-Olight style dock charging
–18650
-xml2
–980
-tailcap rotary dimmer
-I’m a newbie in flashlight review but I can try
Rechargeable through micro usb in the tailcap
18650 LiION
CREE XM-L2
950-1050 lumen
In flashlight charging via micro usb, momentary on switch, which is lockable through rotation and/or freely adjustable brightness including moonlight.
1. Rechargeable
2.18650
3. Xml2
4.1000ish lumens
5. Magnetic dimming knob.
6. Yea I have done reviews. I reviewed two of your lights… The ddt40 and the SA04. My other reviews can be found in my signature. I do video reviews only.
1. If the flashlight is rechargeable or un-rechargeable? It’s USB rechargeable.
3. What kind of LED does it use? Looks like an XP-G2, maybe XM-L2
4. What would be the lumen output? If it’s XP-G2 it could be 600 to 850. If it’s XM-L2 it could be 900 to 1200.
5. What features would this flashlight have, as you know IMALENT flashlights always have innovative feature for each flashlight? It looks like capacitive touch on the tailcap with a rotary control for brightness level.
6. If you can do flashlight reviews or you have time to take some good pictures or videos, let us know several of your history reviews or videos, you will have priority to get the chance. I don’t have any really deep reviews but I’ve posted beamshot comparisons. I can definitely take pictures and do video reviews. Here’s a few links…
Thanks IMALENT for this guessing, and nice giveaway
1.Yes its micro USB rechargable
2.Single 18650
3.NW XM-L2
4.860 - 1000 lumens on HI mode
5.Some kind of special pressure sensitive electronic switch ,momentary on,and preadjusted modes ….
6.I have done only picture reviews here on BLF for moded lights, and video for opening packages,but will do my best to do a nice review of your new flashlight if you chose me ……
Rechargeable with micro USB.
18650 or 2x CR123s or 2x16340
Cree XM-L2
Moonlight till 900 - 1250 lumens
Infinitelying variable brightness with the tail knob, touch button instead of physical mechanical or electronic button.
I have taken beam shots but not a full flashlight review. Beamshots
