It isn't. It is in RemanG's thread about the 18350 battery tubes for the A6.
We are trying to cover all of the bases. :) RemanG asked about shortened tubes for the A6 and when Kronos and company did the X6-SE people wanted extension tubes. Therefore, if they are going to make tubes (after we get these finished) then they are going to make tubes that can shorten or lengthen the unit as desired :)
Not completely, this is b.a. of course, love it, enables it to become a hotrod, but it will still not dissipate heat nearly as well as a common aluminium flashlight where heat spreads over the complete body. (agree about the turbo timer)
The Cu will allow the SS light to be run hard and have a good chance at surviving it. Much the same way that Cu enhances the natural tendencies of Al, it at least gives the SS a chance.
Below is the interest list to date. I would like to set the list up in columns (1 left and 1 right) so that you don’t have to scroll so far down to get to the Aluminum X6 list.
IOW…to look like this, but more space in between the two lists:
1. ABC123 SS/Cu NW 1. XYZ123 Al NW
2. xxxxxxxxxxxxxxx 2. xxxxxxxxxxxxx
etc.
etc.
Can someone tell me how to do this in the thread editor?
INTEREST LIST (Stainless Steel X6-SE V2 & Copper K6). Estimated at $80/set:
(Need Min. of 200 sets)
INTEREST LIST (HAIII Aluminum Set). Estimated at $45/set:
(Need Min. of 100 sets)
1. kronological Al NW
2. zelee Al NW
3. southland Al NW
4. southland Al NW
5. southland Al WW
6. southland Al CW
7. djozz Al ?
8. kst Al NW
9. kst Al NW
10. Jubeldum Al NW
11. Ejected Filament Al ?
12. D10ten Al NW or CW if XP-L Hi
13. ahirshy Al ?
14. Chicken Drumstick Al NW
15. ReManG Al NW
16. tristanxoxo Al NW
17. tristanxoxo Al NW
18. mattlward Al NW
19. mattlward Al WW
20. Aardvark Al NW
21. Alexey602 Al NW Hi
22. DanielM Al NW
23. slow2go Al CW
24. chuckhov Al NW
25. Pregulla Al NW
26. magnet Al CW
27. bugsy36 Al NW
28. will34 Al CW
29. Sparkey762 Al NW
30. Malenurse Al NW
31. ahirshy Al ?
32. nguyen Al NW
33. Antenne Al NW
34. Iron potato Al NW
35. Chuckhov Al CW Hi
36. DTJ Al CW Hi
37. Jmpaul320 Al NW
38. Wobba Al NW Hi
39. Tinn44 Al NW
40. Cone Al NW
41. Ilovejesuschrist Al NW
42. B42 Al NW
43. Gunga Al NW
44. Merikgvr4 Al NW
45. Mikeyx Al WW
46. Compression Al NW
47. Trigger619 Al NW
48. Trigger619 Al CW
49. Sonntag Al NW (wants #55)
50. Allthumbs Al WW
51. Mauison Al NW
52. B42 Al WW (wants #42)
53. Xjsnake Al NW
54. Mg Al NW
55. Jescereal Al WW
56. Muto Al WW
57. Seasam Al NW
58. Kst Al NW
59. Wedlpine Al NW
60. Bugsy36 Al NW
61. Thebaum Al CW
62. Sonntag Al NW
63. Keengeorge Al NW
64. Uqs1000 Al CW
65. DavidEF Al NW
66. Kleopper Knife Works Al WW
67. Kleopper Knife Works Al WW
68. Jamjar Al NW
69. DavidEF Al NW
70. Robo819 Al NW
71. Hank Al NW
72. Kbro Al NW
73. Richnpc Al CW
74. Perttuj Al NW
75. gehrmo Al NW
76. ChibiM (X6 CW/K6 NW if possible)
77. cbrake10 Al CW
78. jescereal Al NW
79. SciFiFreak Al NW
80. tizzo Al NW
81. Nguyen Al WW
82. lopedeveg Al CW
83. Bugsy36 Al NW
84. DB Custom Al NW
85. bigrick Al CW
86. Randolph Al CW
87. tas69 NW
88. xelario Al NW
89. WhitedragonBC Al NW
90. twin towers Al NW
91. KeepingItLight Al NW
92. SmokinH Al NW
93. Ray-o-light Al NW
94. twin towers Al NW
95. MaxBeam Al NW
96. illuminos Al NW
97. flashination Al CW
98.
99. dodo Al NW
100. Nisse Al NW (GOAL/Minimum for Al HAIII set)
101.
102.
103.
104.
105.
106.
107.
108.
109.
110.
111. Alexey602 AL NW
1. kronological Al NW 2. zelee Al NW 3. southland Al NW 4. southland Al NW 5. southland Al WW 6. southland Al CW 7. djozz Al ? 8. kst Al NW 9. kst Al NW 10. Jubeldum Al NW 11. Ejected Filament Al ? 12. D10ten Al NW or CW if XP-L Hi 13. ahirshy Al ? 14. Chicken Drumstick Al NW 15. ReManG Al NW 16. tristanxoxo Al NW 17. tristanxoxo Al NW 18. mattlward Al NW 19. mattlward Al WW 20. Aardvark Al NW 21. Alexey602 Al NW Hi 22. DanielM Al NW 23. slow2go Al CW 24. chuckhov Al NW 25. Pregulla Al NW 26. magnet Al CW 27. bugsy36 Al NW 28. will34 Al CW 29. Sparkey762 Al NW 30. Malenurse Al NW 31. ahirshy Al ? 32. nguyen Al NW 33. Antenne Al NW 34. Iron potato Al NW 35. Chuckhov Al CW Hi 36. DTJ Al CW Hi 37. Jmpaul320 Al NW 38. Wobba Al NW Hi 39. Tinn44 Al NW 40. Cone Al NW 41. Ilovejesuschrist Al NW 42. B42 Al NW 43. Gunga Al NW 44. Merikgvr4 Al NW 45. Mikeyx Al WW 46. Compression Al NW 47. Trigger619 Al NW 48. Trigger619 Al CW 49. Sonntag Al NW (wants #55) 50. Allthumbs Al WW 51. Mauison Al NW 52. B42 Al WW (wants #42) 53. Xjsnake Al NW 54. Mg Al NW 55. Jescereal Al WW 56. Muto Al WW 57. Seasam Al NW 58. Kst Al NW 59. Wedlpine Al NW 60. Bugsy36 Al NW 61. Thebaum Al CW 62. Sonntag Al NW 63. Keengeorge Al NW 64. Uqs1000 Al CW 65. DavidEF Al NW 66. Kleopper Knife Works Al WW 67. Kleopper Knife Works Al WW 68. Jamjar Al NW 69. DavidEF Al NW 70. Robo819 Al NW 71. Hank Al NW 72. Kbro Al NW 73. Richnpc Al CW 74. Perttuj Al NW 75. gehrmo Al NW 76. ChibiM (X6 CW/K6 NW if possible) 77. cbrake10 Al CW 78. jescereal Al NW 79. SciFiFreak Al NW 80. tizzo Al NW 81. Nguyen Al WW 82. lopedeveg Al CW 83. Bugsy36 Al NW 84. DB Custom Al NW 85. bigrick Al CW 86. Randolph Al CW 87. tas69 NW 88. xelario Al NW 89. WhitedragonBC Al NW 90. twin towers Al NW 91. KeepingItLight Al NW 92. SmokinH Al NW 93. Ray-o-light Al NW 94. twin towers Al NW 95. MaxBeam Al NW 96. illuminos Al NW 97. flashination Al CW 98. 99. dodo Al NW 100. Nisse Al NW (<span class=“caps”>GOAL</span>/Minimum for Al <span class=“caps”>HAIII</span> set) 101. 102. 103. 104. 105. 106. 107. 108. 109. 110. 111. Alexey602 AL NW
The two parts were done separately and must have been set to cut differently on the CNC machine. Noted and info already passed on to Manker due to Dale’s also very keen eye
