That really sounds like a tube issue to me - Too short.
Thanks,
-Chuck
Thanks,
-Chuck
That’s a perfect illustration why having a production that respects and understands specified tight tolerances matters.
There you have one that is less than .01 too short on one part, and less than .01 too long on the other piece, and — put them together, and hey, this one sample works fine.
Checking one product fails to detect the problem — too much variation around the spec — because some combinations of parts will average out to working properly.
Too much on one part, too little on the other, result — it lights up if you happen to get those pieces put together.
That’s why taking a real sample of the products — not just one, not just one they know works, definitely not one prepared to show as a “sample” — is what you need to check them.
Measure, write down the result, find out how variable the work is.
Given sloppy work with overmuch variability, the workaround — assemblers fishing through the bins looking for a slightly longer tailcap to go on a slightly shorter body tube, trying to make the damn thing light up — isn’t the right fix.
Want to build a modern nation that doesn’t melt down and fall apart?
Here’s how: production tolerance variability specification interaction - Google Search
What are other people’s tubes measured at? My issue seems to be that one of my tail caps. Unless all 3 of my body tubes are too short. If someone just ordered 1 light then this issue may be missed. The only reason I noticed it was because I ordered more then 1 light. I was wondering why one of my lights I had to crank the tail cap as tight as I could to make the light work. When I put the tail cap in the other lights the only way I could get it to work was by putting in a paperclip shim in the tail cap. If people order the 18350 tube the light may not work, but it works with their 18650 tube.
Re the 18350 - You have made a very good point.
Thanks!
-Chuck
What is the proper length and tolerance for body tube suppose to be?
Hi bugsy36 and Mitko.
I don’t know if Mitko has the same issue like me and some others. If so, the bike flasher for example wouldn’t work as it should (only flashing, no continiuous “background” light”), and the battcheck mode wouldn’t function, just like the moon mode. If that’s the case it’s very likely a problem with the 7135 solder joints. When I received my light and experienced that issue, my first thought was I am going to reflash it. TK asked for some macro shots of the driver and when I posted some, DEL suggested that the 7135 solder joints could be bad by the looks of it. And he was right. With that kind of issue, reflashing the driver wouldn’t do anything to get rid of that.
Has anybody measured the tail cap threads on the tube,from the end of the threads to where the tailcap seats? Seems like if the whole tube was too short it would be noticeable. The tailcap would be hard to twist on because of the springs compressing and there would be a gap between the body and tailcap.
When I put a unprotected battery in mine I can barely feel the springs compress, I tried a protected battery and I can feel the springs compressing more but the tailcap is still easy to put on.
All 4 that I got work great, but I don't have anything to measure mine to post for comparison.
I measured the tailcaps from the brass ring to the top and the I got 4.3, 4.4, and 4.6. The tailcap I’m having and issue with is the tailcap that measured 4.6.
Well, there’s a lesson here — as always!
We hear a lot of fuss about charging variations of a tenth of a volt, when the accuracy of the meters being used is likely no better than that.
Now we’re on the receiving end of a production process that — as illustrated by matching tubes to tailcaps — needs not just accuracy but also repeatability
We can hope someone on the manufacturing end knows how to do that and just didn’t get consulted, or listened to.
On the receiving end — well, what can we learn? Anyone competent in machining and QA/QC around to start a topic? I’d love to read about this.
Lots of info on the Internet of course. But that’s the Internet.
——————-quote starts here——————
————quote ends here — see link for more, or find something better ——————-
Dunno how they do it at Manker or wherever the pieces are coming from.
This is to try to learn something about how we should do it on our end —- because we can make some pretty wild claims here if we don’t know the limits of the tools we measure with.
Just sayin’
Sorry for drifting into Meta stuff. Figured it needs to be said somewhere. Hope someone knowledgeable can start a thread and port this stuff over.
Quality control over at Manker must be going to test each light now, the amount of money someone is losing with these errors is too much for Banggood to think about handling, I’m sure. I wonder if they will be mixing and matching the parts, to try to get everything to work. Or will we see shims added in the next deliveries upon resuming? :~
I hope they do the right thing.
I hope so too…
This mixing and matching of parts to get the light to work is going to cause some peoples 18350 tube not to work.
Got mine today, everything works and looks fine. I took it apart to bypass the springs and everything was screwed in with enough force and wasn’t too hard to unscrew. I changed the reflector to a TIR while it was apart and I’m loving the setup, however the UI does take a little bit getting used to.
Hi,
I received my 2x 3D tinted lights yesterday and one of them has a horrible yellow green tint to it. I purchased 2x 5A and 2x 3D and one sticks out like a sore thumb. It is really hard to take a pucture of, but it appears that the dome on the LED is either damaged or partially dedomed. Can a bad dome affect colour this much?
The awful coloured light is visibly dimmer and a ceiling bounce test with my lux meter (phone) confirmed my suspicion.
When looking directly at the unlit LED and the reflector, it does not reflect a nice even yellow colour like the rest of my lights. I have taken some photos using my UV flashlight to reflect into lights to show the oddness I am seeing.
5A
5A
3D
“3D”
Below is a picture of all four lights; I hope it’s clear which one I’m referring to.
-> 3D - “3D” - 5A - 5A ->
And now just three
-> 3D - “3D” - 5A ->
I’ve been seeing a few other users with tints similar to this and I’m not sure if this is a completely different bin or bad dome. I would love to know what the experts thinks. I am thinking about email Neal’s assistant because it is significantly dimmer and after being so spoiled with such beautiful tints (thanks to everyone involved in the GB) I just don’t see myself using the light.
Link to imgur album: Manker A6 - Album on Imgur
-Thanks
The yellow-green 3D is likely dedomed. Removing the dome tends to warm up the beam by about 1500K and makes it more green. You’ll need to get a new emitter or head or something to fix it…
Neal is working this issue with the short tubes… He is more worried about further issues than most of us. I am sure if the tolerances stack in a bad way and an 18350 tube doesn’t work for someones light, that Banggood will make it right….
What TIR did you use? Would you have a link?
Ref, Tailcap - Bodytube Problem. To Me it looks like the Tailcap Spring Coils are bottoming out before the Tube+Tailcap make contact. Cut 1 turn off the Spring to Fix.
Assumptions are just that. Be patient and let them do what they said they would do. They said they would provide better quality and QC - we just have to wait.
