bibihang, Richard has the high current 17mm MTN-MAX driver? It can still handle big currents & has been tested to withstand lots of stress tests. The 22mm version is probably better, but I’m not sure if its necessary?
I think its important that Simon makes sure that there’s enough height in the driver cavity for the driver to fit - the inductor takes up some space.
For single cell as it is now, the 17mm driver is perfect - lots of options, but of course I only want a FET+1 anyway. But yes, for 2-3 cell options, the bigger driver is almost a definite.
Ohh btw - Simon gave me 15% off the entire order .
Wish I could jury rig an e-switch in this light though - would be perfect for my new 45/85 e-switch firmware (in here: https://budgetlightforum.com/t/-/34900). I always preferred e-switch's, but now, it's a whole new realm with almost all the bells and whistles, and room to add even more features. Just give me a side mounted switch with 2 wires hanging off of it in the pill, and I'll be happy.
Yes, I do aware of Richard’s buck driver, in fact I’m running it in my modded 1405 now and it rocks.
But,
The price of the 17mm MTN-MAX high profile buck driver itself is quite reasonable actually, but for those who live outside USA, the shipping fee is insanely expensive, which is not quite affordable to many people.
2. This is not to say that Richard’s driver isn’t good (in fact they are awesome), but larger pill opening means more driver options available. For example if I already have a 21mm buck driver in my storage box I can use it in the light directly, don’t need to order another driver for that matter.
3. Who knows Richard or other fellow BLF members will design an even better buck driver in the future, but comes in the size of 21mm?
4. If you want to use a 17mm driver in a pill with 21mm opening, it isn’t difficult. You can simply add a contact board to your 17mm driver, or press-fit a brass ring into the opening to ‘convert’ the opening diameter.
How do you get a 6v 5amp (Max) Buck driver to rock and roll a XHP-70? :~ It just starts to get bright at around 6amps? Then there is the heat to deal with, (heat sinking,potting) so you don’t smoke the driver? Can you get a buck driver to do 7-9amps? Cause I’ve been told different? Wouldn’t you be better off with a 7135 driver, if you want or need regulation? Just asking? On a side note- I would like to see a thicker shelf if running a XHP-70, like 10mm or better? Driver cavity diameter, don’t matter to me, I can make adapters, for anything? So what ever get’s decided I’m good with.
The measurement of the inside (battery tube) end to end is almost exactly 2.75 inches or 69.85mm. This would of course be smashing the springs to non existence so I’d say it’s a no for a 26700.
In short… I love it. It’s excellent even in it’s stock form. I honestly didn’t expect to be very impressed with it until it had been modded with at least more power. Mine is just a pure stock L2 with the default XM-L2 yet I’m very impressed. The throw is ridiculous for a stock light, pretty much matching my heavily modded XinTD C8. I’ve never seen a dome-on emitter throw such a tight defined hotspot. With a few tweaks it has crazy potential. Keep in mind this is not a pocketable light. It’s big and heavy…beautifully heavy. So much aluminum that at 5 minutes on high there is no heat to be felt. I just tested indoors sitting on a table pointing at the ceiling with no additional air circulation. At somewhere between 12 and 15 minutes the body started getting warm and then it quickly spread throughout the entire flashlight body. The huge deep cooling fins just eat heat for breakfast. In a couple weeks a few more of us (particularly those with modding skills) will have these and can offer more valuable input. I know Simon wants to move on to the next version but honestly I think it would be a big mistake to drop this design. You will absolutely NOT regret buying this light. It’s just awesome. I don’t own anything like it. Honestly I think Simon knocked this out of the park. He hesitated on making it because I think he actually lost money on the original L2 and he is a little uncomfortable selling a light at over $40 but when you have it in your hands you see exactly why it costs that and it’s a bargain at that price. The threads are beautiful and disassembly and reassembly is butter smooth. I will try to get some decent pictures tomorrow. I need daylight for good shots since I’m just using my phone for pictures these days. I can’t promise beam shots but I’ll try. Sorry for being so wordy but that’s just kinda how I roll. :bigsmile:
Can anyone give me a rough idea of the hotspot size at 100 and/or 200 yards? Also, any thoughts on a XPG2 in one of these. I’m thinking long range hunting/search light.
Okay so I have good/bad/mixed news from Simon… The following statements are where we stand with any changes as far as I know. Simon told me this yesterday. I do my best to summarize what the majority of BLF is asking for but I think Simon gets input from plenty of people and when it comes down to it he calls the shots. With that said here is where things stand:
There will be no extension tube or OP reflector for the current L2 At least for now he does plan to continue to sell the current L2 in host form and as a complete light.
The upcoming (2×26650) version of the this light is being designed specifically as an XHP-70 light and it will have a new name. It will be available in complete light and host form in maybe 2 months if there are no further stumbling blocks.
The complete light will come with an XHP-70.
MCPCB will be 20mm.
Driver shelf will be either 22mm or 30mm. If 30mm Simon plans to package it with an adapter for a 22mm driver.
I don’t have any details on what driver he plans to use in the stock light and I think it’s a little early to ask prices. Originally it was supposed to have a side switch but Simon cancelled that because he says “side switch is no good for DIY”. Those were his words. I don’t think the general BLF population agrees with that opinion and I’ve told Simon as much but again it’s not my call. If a lot of people speak up and cry out for the side switch I will be happy to reiterate our “group opinion” but I can’t speak for all so make your thoughts know on the side switch.
Any way you look at it I’m excited to see Simon selling a stock Convoy equipped with an XHP-70! :bigsmile:
OH BOY! |( NO extension for the L2? |( But I know why… if he did make a 2x26650 extension for the L2, who would want his “NEW VERSION”? As far as the E-Switch I would like it…IF it had a push button and it also activated the light too? Take the UranusisonFire 818, it has both E-switch and push button, and you have the choice of using one or the other to activate the light and the push button locks it out too, way cool!!! Or it might as well be a X6?
The bigger and fatter the light, the more important a side switch becomes. Larger lights are difficult to shift in one hand from a “pointing” grip to a “mode selection” grip. So the side switch is a game changer for sure.
That said, the kill switch in the tail ensures safe travel, long term emergency storage with no drain, and a lock-out ability for various reasons.
I cry out for a side switch too. :_(
The Convoy L4 is a favorite due to it’s combination of tail clicky and side e-switch. Carry on with that lineage and be popular or lose out to the other guys.
